Question about Ovens
Indesit KD6C35 top oven is not working, but grill does work.
Presumably they use the same element? So could it be the thermostat? If so, how do I get to it?
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1462 Answers
    SOURCE: delonghi esf461st oven not heating up
    grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
    Posted on Sep 06, 2008
    barkencoa
    • 3463 Answers
    SOURCE: no heat when i switch oven on
    There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
    If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
    Remove and replace.
    If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
    Plz rate my solution.
    thanks,
    Posted on Jan 02, 2009
    • 12 Answers
    SOURCE: indesit fde20 main oven wont heat up
    sounds like the circular element at the back of oven has blown.
    Posted on Oct 24, 2009
    barkencoa
    • 3463 Answers
    SOURCE: Dead oven despite element replacement?
    If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
    What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
    Please rate my solution.
    Thankyou.
    Posted on Feb 02, 2010
    Top element not warming but does work when grill is activated
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer?
    http://how-2-repair.com/buy-paul-a-beer/ Paul is from the Naturally he would appreciate beer How to Repair Home...
    Jan 11, 2014 | Smeg Ovens
    Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
    First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
    The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
    To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
    So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
    Best of luck
    Nov 23, 2010 | Stoves 720EF Electric Double Oven
    Hi right my indesit 29229 fan oven is not working it blow the power in the house now the top oven is work but the bottom one wont heat up the fans working and thats it do you think its the element thats...
    To blow the house trips it must be the element
    Thermostats do not normally go short circuit.
    The elements can be replaced quite easliy and cheaply
    I would check that the fan is turning freely before you buy the element
    Feb 24, 2010 | Ovens
    Zanussi electric double oven. Top oven not working.
    It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
    Hope this helps.
    Feb 10, 2010 | Ovens
    Indesit fde20 main oven wont heat up
    Oct 23, 2009 | Ovens
    Oven not heating up but fan and light on
    oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
    Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
    Indesit grill element not heating up
    It may be the oven temperature sensor.
    Mar 24, 2008 | Ovens
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
