Question about Microsoft IntelliMouse Trackball 1.0
Right outside button not working
The right outside button doesn't work or doesn't seem to. Anyway to test this button? Low level?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Control panel - mouse icon and change it to eft handed and hit apply if that works its not the mouse - if its an older mouse take it apart and use a pencil eraser to clean the contact points on the mouse
Posted on Jan 16, 2013
I have a 2004 Monte Carlo SS S/C and it is throwing multiple codes. P0068, P0001, P0018, P0054, P0085, P0050, P0055, P0060, P0028, P0084, P0008, P0009, P0069, P0070, P0300 I need some serious help! The car...
What you do is Google the codes & read up on them
Type: 2004 Monte Carlo OBD POO68 etc
I would guess when you say you need help you,
don't have the years of experience & test equip
to work on it anyway
Sep 12, 2013 | Cars & Trucks
Doorbell doesn't work
It seems your doorbell transmitter got wet and corroded the contacts.
These push buttons are not sealed at all and thus will let rain, snow etc. eventually corrode the electronics.
Solution: Find a new push button on eBay.
Cheers
Feb 26, 2013 | Desa International White Wireless Plug In...
Huawey g6600 doesn't turn
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 29, 2012 | Other Huawei Passport G6600D Unlocked Dual...
My washing machine would stop and beep and not advance to the next wash cycle and it was taking forever to fill up. I did the diagnostics and found it to be #49 which is a faulty hot or cold water valve. ...
Sorry for the very much delayed response due to site changes which modified the notification system.
Anyway, you should try holding first the WASH TEMP DOWN button then the POWER button until there's a beep. If it doesn't work, use WASH TEMP UP instead.
Make sure the Restart feature is turned on and the Recycle feature is turned off if all else fails. During the diagnostic mode use the WATER LEVEL DOWN button to turn RESTART on by pressing the said button until the LOW WATER LEVEL LED turns on. Use the WATER LEVEL UP button to turn RECYCLE off. The MEDIUM WATER LEVEL LED off indicates RECYCLE OFF. To set these modes in EEPROM the Advance button must be held while selecting Restart or Recycle. Power off the machine thereafter to complete the reset.
Oct 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Hi, our RXV465 was working great until a few weeks ago. We were watching a movie, and all of a sudden the movie sound switched to radio static. No errors were shown on the display, and we have gone...
According to your description, there is the high possibility that the button for one of your audio calibrations was pressed on the remote. Frequently referred to on many models as 'level', pressing this button will enable a built in test signal called wide band pink noise, sounding exactly like radio frequency noise. Pressing it again or repeatedly will resolve the problem.
However, if what you are experiencing is not just a pure static-like tone but also your intended audio with it, then it is a different problem that the root cause of may not be in the receiver.
Aug 24, 2011 | Yamaha RXV465 51 Channels Receiver
The radiator and cap just replaced, tune up and oil change current. 1999 jeep cherokee 2.5L 4 cyc engine losses power after this last servicing. i use o'reilly octane booster and so far this seems to...
You don't really have a mechanic that has much knowledge
Without the vehicle to test drive & do some testing on it,
there is no way to just guess & I suspect you wouldn't
understand any of our suggestion anyway.
Find the best established shop,one that has been in the same
family for 20 or 30 years
You have to go on a road test with these people before you
leave a vehicle. Be part of the solution,go to the shop on a
supprise visit & as a lot of questions,walk into the service bay
If that isn't some they want you doing take your vehicle &
go elsewhere.
So what test tools they have,study obd2 on internet & have some
trick questions ready to fire off.
Jul 12, 2011 | Jeep Cherokee Cars & Trucks
Jeep makes a whining sound when I turn left sometimes. Doesn't do it when turning right ever and only seems to do it when driving forward. Only happens at low speeds and doesn't seem to affect...
It MAY,,,,,, be the start of a power steering pump problem.Just maybe.The pumps can moan and groan without leaking,so keep an eye on it.Hope this helps.
May 19, 2011 | 2004 Jeep Grand Cherokee
Microsoft IntelliMouse Trackball 1.0 Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
