I have a yellow bulb sign with an exclamation mark & it says drivers light On. What does this mean
  • 3,799 Answers
The device that this is next to needs the Driver updating. If you "right click" and select "Update Driver" the system should do it for you.
Posted on Jan 07, 2013
4 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: USB drivers
ahuh..remove that usb controller, and then do a hardware scan for differences should work well
and by the way, got backup for that Dell?
Posted on Feb 20, 2008
Randy V
  • 236 Answers
SOURCE: video controller problem - has
Yes, you need the drivers for the device.
Go to the manufacturer's website. Ex. Sony, Toshiba, HP, Acer, etc.
Look for support, drivers and downloads.
Enter your computer model.
In the list, download the one that says display driver or graphics driver.
Run the program.
Posted on Aug 04, 2008
sys_admin
  • 829 Answers
SOURCE: In device manager Network Adaptor
Completely remove the LAN adapter and disable "Plug 'n Play OS" in the BIOS, as follows:
1) Remove the card from Device Manager, under Network Adapter
2) Delete C:\WINDOWS\INF\DRVDATA.BIN
3) Delete C:\WINDOWS\INF\DRVIDX.BIN
4) Delete the following files. Not all of them may exist.
  • C:\WINDOWS\INF\NET82557.INF
  • C:\WINDPWS\INF\NET559A9X.INF
  • C:\WINDOWS\INF\NET5579X.INF
5) Shutdown and restart the PC, and enter BIOS setup.
6) Find the option for Plug and Play BIOS, and disable it.**
7) Restart Microsoft Windows* 95 and use the Intel® installation diskette to reinstall the adapter.
Posted on Dec 14, 2008
What does the yellow exclamation dashboard warning light mean on a 2009 Porche caynne
I believe there is two different yellow exclamation warning lights on this type of car. If it has a bulb highlighted around it. It warns you to check for a bulb that is out in lights. Highbeams tail lights etc. If it has a yellow circular type of outline around the warning exclamation light. Then it may have to do with inflated tire. Or a low pressure in tires. Check the pressure in your tires and go from there. Hope this helps.
Mar 18, 2018 | Cars & Trucks
Tip
How to check if your system needs drivers
WINDOWS XP
Goto Start > Run > type "devmgmt.msc " without quotes and hit the enter key. You will get Device Manager opened. Now see if you see any yellow exclamation mark. If you see yellow icon that means the current drivers are corrupted or the drivers are not installed.
To fix the issue use windows update site and install all the hardware updates.
WINDOWS VISTA & WINDOWS 7
Goto Start > In Search type "device manager " without quotes. > Now locate device manager and open it. Now see if you see any yellow exclamation mark. If you see yellow iconthat means the current drivers are corrupted or the drivers are notinstalled.
To fix the issue goto control panel and open widows updates and install all the hardware updates for your system.
on Dec 08, 2009 | Computers & Internet
What does a yellow exclamation point inside a triangle warning sign mean. Now check engine light just came on.
The yellow triangle with an exclamation mark will typically be accompanied by a message explaining what's gone wrong. Hopefully it will be self-explanatory - such as a low reservoir for the windscreen washer system.
Dec 28, 2017 | Cars & Trucks
Code v8309 on t320. Has a exclamation point on dash in a yellow light. Machine works fine but I can hear high pitched noise coming from it lately
Exclamation mark in the yellow sign according to my knowledge is an air bag off sign, but I cant understand where the high pitch sound is coming from?
Mar 12, 2016 | Cars & Trucks
Yellow oil light with exclamation mark
time for a service. or oil to low. time to top up.
Apr 01, 2014 | 2007 Toyota Hi-Ace 220
You plug a network cable into the motherboard (E219542) and the light glows yellow. What does this mean?
this might be the driver
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
if you need more help with this posta reply
hope this helps
Oct 11, 2012 | Dell Computers & Internet
Warning Lights
Are your hazards lights on? I don't know your car but The triangle most of the time is hazards lights. Now when you turn your key on all the light should come on then go off, If on stays on in some cases it could be just a bulb. To check your Bulbs use you turn singles / blinkers. You can get them on by turning key to on with out starting car. Then turn on our left by pushing switch down first. Check driver side front & rear. Then check passenger side by switching to the right switch up. Good luck
May 17, 2010 | 1994 BMW 3 Series
Vw jetta 2OO7(or O8) lightbulb sign with an exclamation mark?????
this says that one of your bulbs is not operating. check all lights round the car, including the brake lights (have somone to oberatge the brake while you have a look). you will see one not working. replace and sign goes away
Jun 03, 2009 | 2001 Volkswagen Jetta TDI
Lightbulb with exclamation mark inside????
This means you have a light buld not working some where in the front or rear lights.When you fix the problem the light will automaticy go out hope this helps.
Video driver loading problem after clean XP home install
Are you sure that you are installing the proper driver, I mean are u installing the driver for windows xp? If you are not able to install in the proper manner. Do like this Right Click on My Computer>Manage>Device Manager>Display Adapters. If an yellow exclamation mark is shown then it means that you have not installed the driver and if its not showing any confilct (yellow exclamation mark)then you have already intalled the driver and your video card is also working perfectly. And the problem could be something else. If confilct(yellow exclamation mark) exits.. Do like this. Right Click on the exclamation mark>Update driver>Not at this time> Install from a specified location>make sure u have checked "search removable media..." and make sure that u have put the driver cd in the cdrom and click next. If you have put the correct CD then windows will automatically install the driver for your laptop. During the installation if system shows a message "This driver is not digitally signed..." Click continue anyway. If none of the above things work. Download the latest drivers from the net. -ShaC
Jul 26, 2007 | Sony VAIO PCV-W20 PC Desktop
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
