Question about Frigidaire PLEF398AC Electric Kitchen Range
I have a frigidare range and it is flashing F10 and Beeping repeatedly
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Here is the probe to order.
Here is the EOC to order.
Posted on Jan 07, 2013
F10 code flashing on my frigidare oven
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electricrange cavity and relay it to the oven's main control so it knows when to shut off the heating elements.
Hope this helps
Bob
Sep 15, 2017 | Frigidare Ovens
Electrolux range error code f10
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, these codes mean to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 02, 2012 | Electrolux EW30DF65GS Dual Fuel (Electric...
The front panel keeps showing F10 Err message ?? And it won't stop beeping, any idea what it could be??
The F10 error code means that was a runaway over heating that occured in the oven. The things that could cause the over to overheat to the exterme of the F10 error code reqirements is during self clean normal cleaning temp. IF it wasn't cleaned just before the F10 error code,first the oven temtature sensor needs to be replaced then if F10 comes back after the sensor is replaced the computer control board needs to be replaced.
Gene
Aug 16, 2011 | Kenmore 46713 Stainless Steel Electric...
Range started beeping and display "F10" code.
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Mar 28, 2011 | Kenmore 91112 / 91114 / 91117 Electric...
When the oven is turned on about 10 minutes later a f10 code comes on with a beeping. I've tried upluging from the outlet waiting 1 min. before reappling the power cord. I still get a f10 code
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Jan 22, 2011 | Frigidaire Gallery GLEFZ384GC Kitchen...
I have a frigidare oven that is flashing a code F-9 when I try and self clean it wont do it and flashes this code and I cant get it to cancel the cleaning mode out now any suggestions?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 16, 2011 | Frigidare FEF336EC Stainless Steel...
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
166 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
