Question about Vacuums
I have a Wertheim 4808 Barrel vacuum cleaner that has suddenly stopped working. I believe that there is a problem with the electrical cord connection inside. I have tried unsuccessfully to open the compartment that leads to that area. One side unscrewed with a phillips head screwdriver but the other side seems to have a different type of fixing screw that I am unable to undo. It is awkward to get at and in a deep slot and the head of the fixing screw? is not visible.
    Sergeant:
    Champion:
  • Vacuums Expert
  • 357 Answers
Take it to your local vac shop for repair
Posted on Jun 12, 2017
SOURCE: how to open the case of a wertheim b20 vacuum cleaner
Take out all the obvious screws around the base and coloured top using the appropiate driver.   There is one screw under the flap used to hold the dust filter in place.   The flap is spring loaded and can only be removed (as I see it) once the top is taken from the base.   To remove the screw I used a pair of long nose pliers and some patience.   Once the top is clear of the base, other screws can be easily seen and removed.
My problem was a badly worn bearing at the commutator end of the motor.   There was so much movement that the brushes would not follow the commutator with a result of excessive noise and sparking.   The brushes had dug into the commutator segments and chipped etc.
The bearing is permanently pressed into the motor end and cannot be replaced.   This means a new motor which, in my part of the world, was quoted as $250.00.    My neighbour will be purchasing a new vacuum cleaner but after 15 years with the old one he hasn't done too badly!
Posted on Mar 25, 2009
Bob Gemmell
  • 209 Answers
SOURCE: HAVE A RC1400 THAT WON'T RUN.
Should be size 15 or 20 torx bit screwdriver required
Posted on Aug 21, 2009
VacuumRepair
  • 438 Answers
SOURCE: Having trouble with electrical cord.
Greetings from GoVacuum.com,
I'll tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores2_bing.gif. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
GoVacuum.com
Posted on May 13, 2010
VacuumRepair
  • 438 Answers
SOURCE: Am attempting to get 'inside' the vacuum to
Hi There,
Here's a link to a repair solution that I've done explaining how to diagnosis the cord reel, and open up the machine. The model this is done on is not the same exact model as yours, but the repair will be almost identical. Usually when this happens all of a sudden, chance are good that you need to replace your cord reel. Due to a request by the manufacturer we are no longer allowed to sell the cord reel online, however if you need to obtain one, just give us a call and we'll be happy to provide one for you. Hope this was helpful! If it was, please be so kind and rate the repair, or leave some feedback for me.
http://www.fixya.com/support/t4509692-miele_solaris_will_not_turn_s_plugged_in
Posted on Jun 17, 2010
SmartAlec
  • 171 Answers
SOURCE: How do you open a wertheim 2000P vacuum cleaner?
SmartAlec from NelsonVacuums.com.au here. The ET2000 has a latch that is located at the very end of the machine lid (about 6 cm in front of where hose clips in. If you sit the machine up on its back end you should see the black lever that needs to be pushed in. Now I will also say that it is possible that you have actually been pushing this but the lid still wont open, this is because every now and again the whole latch moves itself out of alignment by about a milimetre. The easy fix for this is a gentle screw drive to assist the relesing of the catch, this needs to be gently pushed in at the same time as squeezing the latch (hand at top of latch screwdriver at base kind of toward the middle of machine). You should be able to get it open like this with only light pressure. Now of course if you need bags or filters please visit us at NelsonVacuums.com.au.
Kind regards Alec
Posted on Aug 02, 2010
Why did my carpet cleaner suddenly stop working and now won't turn on?
-Mostly broken cord. Check and replace it.
Good Luck
Mai
May 18, 2015 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    Wertheim vacuum cleaner 2000 does not seem to be having enough suction
    If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
    Regards
    Jun 18, 2011 | Vacuums
    Sebo Automatic X1 Stopped. Yesterday my Sebo stopped working. I know this can happen if it gets blocked and overheated so I checked for blockages, none. And left it too cool down. Tried it again but it was...
    Ok, thanks for the clarification. Even though the cord doesn't have any external damage, it's still very possible that it has gone bad. When a Sebo upright doesn't even start, this can mean one of several things. The parts that could go bad that would cause the machine not to turn on would be the cord (most common on a Sebo), the on/off switch, the PC board that's on top of the motor, or the actual motor. In the 7 years that I've been selling Sebo, I have only changed out one PC board, and I've never had to replace a single motor on a Sebo yet. I have had to replace several cords over the years, some showing external damage, others didn't show any damage.
    The cord and the switch are going to be the easiest parts to test, and also happen to be the most common, so this is a great place to start.
    Here's how you can test the switch and the cord on the vacuum cleaner. You'll need to have a simply Electrical tester that will test if current is going through the cord. Here's a link to a similar one that is very inexpensive that I used in this repair solution:
    http://www.homedepot.com/h_d1/N-5yc1vZ1xh7/R-100183054/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
    Step 1. Unwrap the electrical cord from the vacuum cleaner, and set the entire cord aside. Also remove the on-board wand that rests directly behind the bag housing. After the wand has been taken out, you should see on the left side of the vacuum where the handle goes into the body of the vacuum a little gray lever (my picture this lever is yellow as I only had a Sebo X5 on the floor, but the repair is identical). This is what the lever looks like:
    Step 2. As you'll see if you look closely, the lever says "closed". Turn the lever towards the front of the vacuum so the lever reads "open".
    Step 3. Once the lever is moved to open, lift straight up on the entire handle assembly to remove it from the vacuum cleaner.
    Step 4. Once you have the handle assembly out of the vacuum cleaner, turn the handle upside down. You'll be able to see two small metal electrical terminals that connect into the base of the vacuum where the handle meets the vacuum cleaner. Make sure that both terminals are visible. I have seen a few Sebo's where the handle has come loose, and these terminals no longer make connection to the rest of the vacuum, causing the vacuum not to turn on. You can re-attach the handle into the vacuum cleaner, turn the lever on the side from open back to closed, and test the vacuum to see if it comes on.
    Step 5. If the vacuum failed to come on after reinstalling the handle, take the handle back out of the vacuum. Put one of the wires from your electrical tester into each terminal in the bottom of the handle assembly. Make sure that the tester is actually making contact with the metal terminals. It should look like this:
    Step 6. With each of the electrical tester wires pushed down into the handle and making sure they are making contact, plug the cord into a standard wall outlet. If current is present, the electrical tester will light up. If not light comes on, try flipping the on/off switch and see if this has an effect on if the tester lights up or not:
    As you can see in the picture above, the cord and switch on this vacuum are good. If your tester lights up when you put it into the handle, then this means that your cord and switch are good. This means that either your motor, or PC board have gone bad.
    If the tester signals that you don't have any power at the bottom of the handle, then this means that either your switch or your cord is bad.
    If you will please let me know the results of the electrical test here on the bottom of the handle, I will then go into the next steps of the repair, and explain how to open up the machine and either replace the cord / switch, or if you did have power here, the pc board or the motor.
    Please just use the clarification request form that you used last time. I hope this was helpful in diagnosing your machine. If this helped you, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of the repair.
    I look forward to helping you fix your Sebo.
    Chris J.
    GoVacuum
    Apr 06, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
    Power cut off after handle was dropped on floor while vacuuming
    connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
    May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
    How to open the case of a wertheim b20 vacuum cleaner
    Mar 24, 2009 | Vacuums
    Was vacuuming fine and suddenly the thing won't turn on. Tried another plug.
    Same thing happened to my Wertheim 4030. It turned out to be a broken connection in the retractable cord plug, no doubt due to continual shock upon retraction. How did I find it? By pulling the top off and first checking the internal switch was working with an ohmmeter (definitely no power for this test) Then plugged in, powered up & checked if any power to switch with AC voltage tester(be careful and have unit RCD protected for your safety) None showing, so checked if power at internal reel. None, so switched off power and checked continuity of cord for active and neutral continuity. None in one so cut off plug and checked again OK so new plug fitted and reassembled. If I had power to the switch originally, the motherboard/rheostat or motor may have been the problem. Hot wiring the motor would have determined which(unlikely to be both but a possibility) Repair or replace faulty item, obviously checking motor brushes first. Electrical is simply a matter of isolation and elimination.
    rjjs
    May 16, 2008 | Hoover Vacuums
    Vacuums Logo
    71 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
