Question about Jensen VM9510 Car DVD Player
Jensen VM9412 Video BYpass
If any one can help???? I set a toggle switch on the brake to create the bypass. after using 4 times it stopped working. Then I found out about the secret codes, but all the codes ive tried have not worked. Does anyone have this unit or have the correct code for the VM9412.
  • Seth Diget Jul 03, 2007
    If you set up the toggle switch follow this very closely. 1 make sure switch is off before starting the head unit into video. if you do it to many times you have to remove power and start over. next once the blue screen comes on flip the switch on for 3 seconds then off then back on and youll be GTG. it has been working great other than remembering to shut it off before playing video from my zune. BUT if anyone has a code please. My wife doesnt always remember and I really dont feel like popping the fuse that much.
The solution that was givin for vm9412.
going to SET UP
Then Language.
Then on your remote push 543210.
Press the Hammer & Screwdriver symbol.
Click on praking brake overide and turn it on.
Then hit the X at the bottom of the screen.
And say good bye to the pink wire bs & ground.
This solution was awsome it only took one try very easy!
I Give total props to FixYa.
TTTHHHAANNKK UUUUUUUUUUU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Aug 26, 2008
All you have to do is on your remote push setup and then LANGUAGE and then on your remote push 5 4 3 2 1 0 and then the menu will come up and then there is a hammer and a screw driver or something and click on that and then click on the parking brake override and turn it on then puch setup again
Posted on Apr 08, 2008
Thanks this has been great
Posted on Oct 12, 2008
Audiohead77 Thanks a bunch for the info on bypass worked great,that park brake bs wasn't working most of the time.I was spending a lot of time just trying to get it to work.I was about to return the unit till I stumbled on your post. Thanks again
Posted on May 20, 2008
SOURCE:
How to bypass brake jensen vm9215bt
Did this work? none of the codes (543210 / 1264) work for me. I dont want to hardwire it.
Oct 22, 2012 | Jensen VM9215BT
What would be the best way to bypass the E-Brake on a Jensen VM92
If you have the old firmware then all you need to do is ground the parking brake wire
OR
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jul 02, 2009 | Jensen VM9510 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Wont play dvd jensen vm9311
You can bypass all that. Here's how:
This will work without having to do anything to the pink wire - just tape it and leave it alone. But the next time you unhook your battery cable you will have to put the code in again.
Put in DVD
When the blue screen comes up, hit STOP twice on the remote
punch in 1,2,6, and 4
hit DOWN 1 time
hit PLAY/ENTER (although you can't see it, this turns off the parking brake bypass security feature)
**at this point the display became visible and you will now see the menu which makes it much easier.
hit DOWN one more time to change macrovision
hit PLAY/ENTER
hit SYS SETUP twice to save and exit menu
From now on, you can just put in a movie and it'll start - no more grounding or toggle switch procedure, and you don't have to use the e-brake.
Oct 22, 2008 | Jensen VM9510 Car DVD Player
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
May 21, 2008 | Jensen's VM9312 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Mar 01, 2008 | XO Vision XO9013 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Brake bypass
just run a toggle switch from the pink wire on one side and a ground on the other and ground it to your ground wire on radio put dvd in wait till you hear the sound and flip switch off and on movie will show even while driving this is for all e brake problems i know this is how i ran mine and everyone else
Aug 29, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
860 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
