I HAVE A HOTPOINT 7KG AQUARIUSA+ WMF740 AND WHEN IT SPINS IT MAKES A LOAD KNOCKING NOISE AND ITALSO LOOKS LIKE THE SILVER DRUM HAVE FALLEN A BIT
    President:
  • 1,922 Answers
The trunnion (spider) behind the silver drum has corroded and broken away from the drum,you will need to purchase a new drum and trunnion and remove the front of the machine to replace it as well as your at it replace the drum bearings for the trunnion shaft while you have it apart,dont wait too long or the drum can completely break away from the trunnion and breach the cabinet
Posted on Jan 07, 2013
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: knocking noise
Your problem may not be a broken spider assembly. My Kenmore Elite (model # 110-42822-203) had a kocking problem as well. After taking the back off, I discovered that the nut holding the pulley to the drum shaft (on the outside of the outer basket) was slightly loose. I simply re-tightened this an the knock went away. The pulley was shifting on the shaft ever so slightly, leading to the knock. Cost of fix: $0. :-).
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Posted on Sep 17, 2009
miket756
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
  • 4 Answers
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Posted on Jun 07, 2010
When on spin mode the machine makes a terrible grinding noise and won't spin on 1200 speed Hotpoint Ultima WT965 7kg
Turn drum by hand, if you feel it catching, its something between the drum and tub, put in through soap draw usually by children. Can be removed by taking out the heater element to get access under drum.
If it feels rough all the way round when turned and it can be lifted up slightly ( free play ) then its probably the drum bearings and seal failed.
Oct 20, 2013 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Mar 07, 2010 | Washing Machines
Miele W1926 washer makes a banging sound when it spins
if i were you fist of all open door then you will see the silver drum on the inside lift the silver drum upwards from the top of it and if you feel a knocking sound then the bearings have worn out expencive to replace them,as sometimes you have to have a complete new drum.rgrds,paul
Jul 07, 2009 | Washing Machines
WHERE IS THE FILTER
this sounds more like grease marks rather than sludgy marks,i bet you the bearrings have worn out,check this out by opening the door and the silver drum inside will have a knocking noise as you lift it up and down,when bearrings have worn out this causes a sludgy diposite,rgds,paul
Jul 07, 2009 | Hotpoint WMA64 Front Load Washer
How to remove the drum
before you take the drum out please do one simple check to see if the bearing have worn out.open the door and lift the silver drum inside up an down now if you ear a knocking noise or feel a knocking vibration then it definately the bearrings have gone.
Jul 06, 2009 | Washing Machines
My kenmore front loader makes a knocking when it spins.
how old?sounds like the bearing are going bad,on yours the tub and bearing are one unit,so you have to change out the whole thing-mike
Mar 24, 2009 | Kenmore Elite 45986 Front Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
