Question about Sewing Machines
I need a Bernina Nova 900 foot control pedal. Where can I find one?
It is old but is there not a solution?
  • Sewing Machines Master
  • 7,365 Answers
Try these sites
ebay
sewvacdoctor.com
a1sewingmachines.com
sewingpartsonline.com
thesewingoutlet.com
Posted on Jan 07, 2013
  • MANDY WENDELL Jan 09, 2013
    thanks Debbi, but so far all I get is that it is obsolete. Another suggestion was to use an universal foot control & rewire it with my old cord. That is probably what I will have to do.
3 Suggested Answers
  • 300 Answers
SOURCE: mi need 1 foot pedal
The cord and the control are sold separately.
If it is not working > bring the machine and the control to a Bernina shop for them to check, maybe it is the cord, maybe the control.
If you lost it you need to go to a Bernina shop and buy a new control and a new cord.
Posted on Jan 15, 2011
SOURCE: Are Bernina Nova 900 foot pedals still available?
My "new" Bernina 900 (I just bought it) has another foot pedal than Bernina that is perfect : a YDK !
Posted on Apr 14, 2011
My Bernina "Record" of 1972 suddenly stitches away without foot pedal command, infact same with pedal unplugged Only way to stop is cut AC power
Something with in your machine seems to be shorting out. Since it is many years old I suspect you have wires that the insuation is rotten and making a short. I have seen this before. Should get it repaired if it's worth it. You could be shocked or hurt.
Oct 21, 2016 | Bernina Sewing Machines
Bernina nova foot pressure
The presser foot pressure is not adjustable on the 900 Nova and is not necessary with any Bernina models from the 117L through the 1630 series. If the presser foot bar is sticking so that it is sluggish to respond to the needle plate, the presser bar and bushings will need to be cleaned of oil varnishes in order to function properly. (99.9% of the problem)
The other potential problem although unusual, is that the machine frame has been damaged from a drop or impact, causing the presser bar frame bearings to be out of alignment, hence a sticking shaft condition. You do not want to attempt to correct this as you will likely ruin the machine. Suggest contacting a specialist
May 15, 2014 | Bernina 1008
Bernina nova
Usually the Niva is a model 900 or a Model 1008 is not a nova?
If a model 900 there is a small hole in the bottom of machine that a small screwdriver can be inserted to rotate the speed regulator
I have often had to remove entire electronic board and send it in to BERNINA to have the electronics rebuilt. With
The Bernina 1008 the least expensive way to cure the problem is to purchase a newer style foot control and cord. In Canada about $99
Bernina Nova 900 air-pressure foot pedal going really fast all of a sudden
the foot pedal would have to be check at a sewing machine shop & they
could tell you more about weather it would be easy to fix or not
Apr 21, 2012 | Sewing Machines
Mi need 1 foot pedal for Bernina Nova 900
Jan 15, 2011 | Sewing Machines
I have a Bernina Nova sewing machine, and am unable to get the foot pedal to work. The light turns on, and it works by manually turning the knob. Is it the foot pedal that is at fault? Or have i missed a...
Some Bernina models have a three application switch.
Light, light and power pedal and just the power pedal.
Inside the machine, at the back of the tower is a circuit board. It could be the contact or wire is broken.
May 09, 2010 | Sewing Machines
Mar 12, 2010 | Sewing Machines
Sewing Machines Logo
196 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
