Stereo reciever wont stay on
M y reciever swithes itself to standby mode after 15 seconds. Wont stay on. all leads are intact.
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model #?
Posted on Jan 07, 2013
5 Suggested Answers
  • 189 Answers
SOURCE: Won't power up.
Although this could be a problem with the unit that will require repair, you can check some things to see if it's an easy do-it-yourself fix.
It might be caused by a short on one of the speakers (most likely) or one of the components (less likely) or be due to a problem with the power from your house (remote).
First, while the receiver is off I would inspect the wires to all speakers to make sure there is no fraying or no strands are touching each other and causing a short.
If this looks ok, you should probably disconnect everything, insure the volume is set to low and then try powering on to see if it will stay on. If it still powers off, you can check the mains (power surce) as a last resort (move it into another room where you are sure the wall plug is on another circuit and try plugging it in there). If that still fails you have a bad receiver.
If the power stays on with nothing connected, shut it off and reconnect the two front speakers first. Try it again. Then add in components one by one and then speakers. Make sure you aren't connecting things while the unit is powered on and try it each time you connect something new. In this way you'll identify the offending component.
I know it's a hassle, but it may save you from having to spend some money repairing or replacing the unit.
Good luck.
Posted on Jan 11, 2008
SOURCE: have insignia reciever model nsr5100,cannot
I can fix it. Call BEEPS Computer Clinic at 614 776 3355.
Posted on Feb 02, 2009
SOURCE: Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
Posted on May 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a problem withmy
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 11, 2011
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
I have an RCA STA 3900 stereo reciever that wont turn on. Standby light is on. Tried resetting it from the back but didnt work. Please advise
A standby condition can mean a fault in the receiver. voltages in the system are off. This can either be a bad diode or power transistor.
Aug 24, 2014 | RCA Sta-3900 Stereo Receiver
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
MY harman kardon avr 21 swithes off about 5 sec after swithed on it goes to standby mode.
u have power supply problem. this is one problem u wont be able to solve by urself. get it fixed by an authorised tech or replace if warranty is valid.
Mar 14, 2010 | Audio Players & Recorders
Enters standby after being on for only a few seconds.
Sounds like either the volume is turned up too loud, or you have a short. Have you tried disconnecting all the speaker leads from the rear, and then powering it on? Usually if it turns on for a short time and then shuts off, it is throwing itself into protection mode.
Sep 07, 2009 | Yamaha RX-V363 Receiver
May 02, 2009 | Audio Players & Recorders
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
Wont go onto standby.
When you press power ( on the wii itself), keep holding the power button for 4-5 second and it should go to standby mode, front led shines RED. :)
Oct 06, 2008 | Nintendo Wii Console
CODE IS LOST AND STEREO WONT COME ON KENWOOD KDC-X769 CD RECIEVER
you have to turn the unit on with the remote so the display is on the code entry screen, then press and hold the toggle button on the bottom right side of the screen for 10-15 seconds, basically hold it till the unit turns back on.....
Aug 09, 2008 | Panasonic CQ-Vd7001U
37 people viewed this question
 Grubhead
Grubhead
