Question about Compaq Presario V1000 Series Laptop Charger (1300678LMD0014139)
Change BIOS to IDE
When I boot my PC up, there's no instruction on how to enter BIOS setup. I suppose it is the ROM Based Setup (F10)? But how do I change to IDE?
  • 2,878 Answers
Not sure what you are trying to do. BIOS controls IDE hardware, which handles the hard drive.
Posted on Jan 07, 2013
2 Suggested Answers
parinasragde
  • 526 Answers
SOURCE: sirs I have not made any
But there is no need to worry. There are many known ways to reset / remove / bypass the password: Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. If it fails, then try to remove the battery for at least one hour. B. By Using the Motherboard Jumper: Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Posted on Feb 25, 2011
I have a worm in my computer. How can I format the disk?
if you format your hard drive you will need to load another operating syatem on on it
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
if you still want to load another operating system
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Jun 20, 2011 | Fujitsu Siemens (MAN3184MCB) Hard Drive
Cd Group Boot Priority not installed
hope this helps
Mar 27, 2011 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
When i install some thing the bios not comes.tel me what is the booting key with step by step
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
hope this helps
Dec 30, 2010 | Computers & Internet
How to master rester a compaq presario sr2150nx
hope this helps
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
??????????????????????????????????????????? hope this helps
Dec 29, 2010 | HP Compaq Presario SR2150NX PC Desktop
Reboot and select proper boot device or insert boot media in selected boot device and press a key message coming upon my hp mini 110
Dec 27, 2010 | HP Mini 1000 Netbook
How Can I boot my Dell Dimension 4700 to a windows XP SP1 Bootable installation disk, I've tried changing the boot sequence and everything:( It just won't work, I don't know where to begin with this...
hope this helps
hope this helps
Dec 15, 2010 | Dell Dimension 4700 PC Desktop
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
I want to reformat my computer, my question was how to first boot my cd rom to install...
Start your computer.
When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
Save-and-exit from BIOS setup.
Insert the disk into the CD-ROM.
Your computer should boot from the disk in the CD-ROM.
Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
Compaq Presario V1000 Series Laptop Charger (1300678LMD0014139) Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
