I forgot my password to my gateway ms2274 - Computers & Internet
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: ggateway ms2274 shutting down wont start up
onehugo, has the inside of the laptop been cleaned out?
The Gateway MS2274, is also known as part of the Gateway NV52 series of Notebook PC's.
Look on the bottom of the laptop, and post the Model Number.
(Examples, NV5207U, NV5211U, NV5212U, and so on)
http://support.gateway.com/us/en/s/notebook/2009/gateway/nv/nv52/NV52nv.shtml
(Clicking on Product Views, then on the different product views given, will show you the ms2274 is part of the NV52 series )
The laptop uses the same cooling system as most laptops.
1) Cooling Tube:
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
At one end of the Cooling Tube there are two small metal plates. One plate sits on top of the Processor. The other plate sits on top of the graphics chipset.
At the other end of the Cooling Tube a Heatsink is mounted.
2) Heatsink:
For this series it is a rectangular finned object. Small strip of metal with Tall, Thin fins protruding from it.
3) Fan Assembly:
Fan set inside a backwards D shaped shroud. (Surrounding cage)
The Fan Assembly draws air up from the bottom, then exhausts the heated air out of the side of the laptop.
Operation:
The two small metal plates absorb heat from the Processor, and graphics chipset.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat along it, up to the Heatsink
The Heatsink absorbs the heat, then radiates it away with the Tall, Thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
This is an up close example of the cooling system used, on the Gateway NV52 series of Notebook PC's,
http://www.laptopneeds.com/parts/show/120817549354/
Scroll the page down to the photos.
The bottom photo shows the cooling system, as it looks removed from the laptop, and the side that contacts the Processor, and graphics chipset.
Here I am able to show you the metal plate surface, that contacts the Processor, and graphics chipset.
With this design there is only one large metal plate to do both jobs, instead of two small separate metal plates.
Coming from the end of the copper Cooling Tube, and going to the Left;
1) You will see a small square, covered partway with a gray Thermal Paste.
(Thermal Paste makes a triangle shape)
This pad sits on top of the Processor/
2) Coming to the left a little further you will see a rectangular copper pad, with gray Thermal Paste smeared on it. This pad sits on top of the graphics chipset.
[ The Processor and graphics chipset, are the two hardware components inside a computer, that give off the most heat ]
Also here you will see at the side of the (Black) Fan Assemblies shroud, is the finned Heatsink.
Point of this long 'dissertation'?
Want you to see the cooling system, and especially the fins of the Heatsink.
Air is drawn up by that fan, and pushed through the fins of the Heatsink.
ANYTHING the fan draws up with the air, is pushed through the fins of the Heatsink
Dust, dirt, hair, food crumbs, lint, ...you name it, is drawn in.
This coats the fan blades, fan's center hub, and surrounding cage. (Shroud)
Also clogs the fins of the Heatsink.
This drops the cooling capacity of the cooling system, tremendously.
The Processor, and graphics chipset overheats.
When a Processor overheats it turns off. (BIOS turns it off)
No Processor operating, no computer.
After a few times of this error codes are logged in. BIOS won't turn the Processor on, until the problem is fixed, and error codes are cleared.
Solution is to clean the inside of the laptop out.
Laptop partially disassembled;
Use an ESD wrist strap, ($3 to $6), and connect it's alligator clip to a good ground source.
Use compressed air for computers, a soft small brush, (Makeup brush?). and Q-tips.
No sir/ma'am.
Using compressed air at the Fan Assemblies opening, at the bottom of the laptop, (Air Intake Duct) WILL NOT DO THE JOB CORRECTLY.
It will just shove the gunk further into the fins of the Heatsink.
Use compressed air at the side of the laptop, and the exhaust port?
Even WORSE!
Also;
You see I mentioned Thermal Paste.
The bottom of the two pads on the large metal plate, on the Cooling Tube, (Whew!), is not perfectly smooth.
Neither is the top of the Processor, and graphics chipset.
A magnified view would show imperfections.
'Pitholes, Valleys, and Hills'.
When the two surfaces are mated together, (Pads on top of Processor, and graphics chipset), they create Air Pockets.
Air is an Insulator. Not a Conductor.
Thermal paste fills these imperfections, and is an excellent Conductor of heat. Transfers the heat well.
After time the Thermal Paste dries up. Caused by age, and the heat of the Processor, and graphics chipset.
Fresh, new Thermal Paste should be used.
The top of the Processor, and graphics chipset, plus the bottom of those two pads on the metal plates, should be cleaned THOROUGHLY!
Then fresh, new thermal paste is PROPERLY applied.
Software problem? Windows is messing up?
NO
You stated the laptop is shutting off, BEFORE the operating system is started.
[ You press the Power On button. This is tun presses against a momentary contact switch. The Power On switch.
The first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, then hands the computer over to the O/S.
The Processor isn't turning on, or isn't staying on ]
I can post links to the NV53 series of Notebook PC's, for a Service Manual, and pictorial guide, for disassembly.
With this info you can crossover easily to your NV52 series.
If you wish to clean out the inside of your laptop yourself.
There is ALSO other needed information I will state along with them.
Post back in a Comment.
Regards,
joecoolvette
(Apologizes for the long solution )
Posted on May 17, 2012
Bought a laptop at auction but don't have password to open up
Have a read.
How to Reset Forgotten Password on Gateway Laptop www.windowspasswordsrecovery.com > Resource > Password
A Gateway password is the password that you must enter to log into the administrator or user account on your Gateway laptop or ... You Forgot Gateway Laptop Password?
  • 4 Workable Ways to Recover Gateway Vista password www.windowspasswordsrecovery.com > ... > Windows Vista Password
    Lost Gateway Laptop password? ... 4 Workable Ways to Recover Gateway Vista password. ... you should login Gateway Desktop and enter User Accounts by clicking ...
  • How to Reset or recover the lost Gateway Laptop Windows ... www.windowsloginrecovery.com/reset-gateway-windows-7-password.html
    Forgot your Gateway laptop password? ... How To Get Gateway Windows 7 password reset or ... Reset Admin or other user account passwords with USB Flash ...
  • Gateway Official Site: Worldwide support.gateway.com/s/Mobile/Gateway/M320/3501937sp34.shtml
    Gateway.com Support. Select a country or region. Americas. Canada (English) Canada (Fran?ais) United States; Mexico; Argentina; Brasil; Colombia; Panama; Peru ...
  • Forgot Administrator Password for Your Gateway Computer ... www.top-password.com/knowledge/reset-gateway-password.html
    Forgot Windows login password for your Gateway computer? ... Forgot Windows 8 Password; Reset Windows 7 Password; Bypass Windows 7 Password; Windows Password ...
  • GATEWAY Bios Password, Unlock Your Laptop in minutes gateway-bios-password.biosremoval.com
    Here is the solution to unlock Gateway Bios Password, Gateway Password, Gateway user ... 2013, Gateway Bios Password, Gateway Password ... M320, M320S, M320X ...
  • How to Reset Gateway Laptop Password Windows 7 - Unlock ... www.youtube.com/watch?v=EUx5AjTCLFw
    • BY LYNDON MOSES
    • 3 MIN
    • 14K VIEWS
    • ADDED 2013-11-25
    Video embedded ยท How to Reset Gateway Laptop ... This may be the fastest way to recover a lost Windows 7 password that ... How to crack windows 7 "user login" password ...
  • Feb 11, 2016 | Gateway M320X Notebook
    I need to replace the network card. How do I do that and what product do I need to buy? Thank you
    as far as i see you the network jack is built into the motherboard,
    you'd either have to replace the mother board
    or purchase a new usb exterior network jack
    http://www.ebay.com/itm/GATEWAY-NV52-MS2274-NV5214U-AMD-motherboard-55-4BX01-051-MBWDJ01001-48-4BX04-01M-/251327720635?pt=Motherboards&hash=item3a844cacbb
    Oct 29, 2013 | Gateway NV5215u Notebook
    Should my fan constantly run when my gateway ms2274 powers on
    The fan normally runs in sync with high CPU usage. So, I would say normal. Go ahead and blow out the system with canned air it has become noisier than usual.
    Oct 25, 2012 | Gateway NV5214u Notebook
    Packard Bell Motherboard Replacement
    Geez I hope not. I abhor Peckerd-Bell.
    (Why?
    Want support?
    Ya gotta pay $$$$$$$. A computer manufacturer I like to stay so far away from, that when people say the name, I say,"Who?")
    Gateway then Acer. When did peckerd-bell get involved?
    http://www.ebay.com/sch/i.html?_nkw=nv5214u+motherboard
    http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=7400
    http://www.aliexpress.com/store/product/Gateway-MS2274-NV5201E-NV5202H-NV5207U-NV5214u-Motherboard-48-4BX04-01M-MB/906865_519039566.html
    Now tell me about the P.B. thing in a Comment.
    Regards,
    joecoolvette
    Aug 25, 2012 | Computers & Internet
    Forgot password on a gateway laptop
    Forgot gateway laptop password? Don't worry about it ,you can use Smartkey Windows Password Recovery to help you to reset forgotten password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
    Aug 24, 2012 | Gateway MT6705 Notebook
    Forgot my password on Gateway laptop PC- model NV52L08u operating system Windows 7- Please help- ROGER
    Hi
    You need to use the Password Recovery Tool to reset the password of your computer.
    You need to view the complete steps. Click Here to Get the software and the Procedure.
    In case if you have any trouble get back to us in Fixya.
    Thank you
    Aug 11, 2012 | Gateway M305CRV Notebook
    I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
    A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
    http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
    Mar 21, 2011 | Gateway ML6230 Notebook
    My Gateway MS2274 won't turn on. What do I do?
    I had the same problem on the same laptop. I took it to a local computer repair shop and it was a problem in the power switch/button. They ordered a replacement part and installed for like $40. Good luck!
    Oct 05, 2010 | Gateway Computers & Internet
    Trying to disassemble MS2274 Gateway laptop--
    you need to replace the DC Jack it will involve soldering a new part. most time the whole laptop need to be taking a part to get the it, so unless you are ready for a big challenge take it a tech.
    May 08, 2010 | Gateway Computers & Internet
    My gateway laptop keeps shutting down. it is brand new
    How long have you had it on. If you are not venting the heat out away from the processor, it will shut down to protect it. I suggest either take a small fan and blowing towards the computer. Or they make a chill pads for laptops about thrity dollars.
    Oct 12, 2009 | Gateway (MS-6946) Modem
    Computers & Internet Logo
    19 people viewed this question
    David Payne
    David Payne
