I moved house and the washing machine won't spin dry the clothes They stay soaked Not sure what I'm doing wrong
  • 18,392 Answers
Check the drain hose as not got kink in it or blocked ,also check the filter with it being move may have dislodged something and gone in filter, if any of these are block it won't drain or spin.
Posted on Jan 07, 2013
SOURCE: not sure whats wrong with my washing machine!
My washer humes like it wants to start but doesn't and i have to constantly push it in an pull it out while its humming, after abot 15 to 20 times of doing this it will eventually start. Help!!!!!!!!!!!!!
Posted on Aug 04, 2008
  • 236 Answers
SOURCE: My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Posted on Mar 13, 2009
proJekttaLon
  • 91 Answers
SOURCE: after the spin cycle runs the clothes are still soaking wet
I had that problem at one time with my old washer and what it ended up being was the Washer Dog Agitators were broken and causing the it to slip and not spin correctly. I would try checking the Dog Agitators.
Here's A picture of a typical top-load washer breakdown to show you where they are located --->Here<---
I hope this helps. If that is the problem I bought mine at Sears for about $8, normally in stock item.
moz-screenshot-2.jpgLet me know if there is anything else I can do.
Posted on May 25, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
After the spin cycle runs the clothes are still soaking wet
May 25, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing machine
most washer weight about 150 to 200 pds.. if you clothes are coming out dry out of the final spin cycle theres nothing wrong...there is always a little water that stays in the washer maybe a gallon or so...
Sep 09, 2007 | Frigidaire FWT647GH
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
