Question about Creda Washing Machines
How does the fluff pipe open in the IDW12 washing machine
4 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: the washing machine won't drain the water, the
drain screen or hose is most likely clogged. That is usually the case when they don't drain. Newer machines are really tempermental this way.
Posted on Jul 10, 2009
  • 272 Answers
SOURCE: I had a cockroach scare and closed off the opening
Unfortunately a lot of us have the straight pipe for a drain that you describe. With no trap it is a source of entry for bugs from the sewer and vent pipe. I have the drain from my washer in the pipe with the rest of the opening covered over with duct tape, As long as you don't block or kink the drain pipe you should have no problem closing the area around the drain pipe. I've been running mine that way for over 20 years now! Thanks for using fixya!
Posted on Nov 05, 2009
  • 215 Answers
SOURCE: Found lots of fluff from a previous wash. Next
To clean pump you will need to unplug machine, at rear using screwdriver remove the panel at bottom of machine. depending on fitting of clip holding pipe onto your pump, use suitable tool to remove the clip. You can now remove the pipe from the pump. check inside the pump also.If you need to remove the tub end of this pipe there is what is like a ping pong ball within the pipe. Make sure you refit this as it acts as a non return for the water.
Posted on Mar 15, 2010
How do I clean a lg direct inverter washing machine?
If it has a sanitizing cycle, you might want to try that, but it can also be a backed up drain that has lint in it and doesn't flush out properly. If you have a drain to outside, pull the drain hose out of the sewer pipe and run an empty cycle and check the manual to see if there's a filter you can clean.
Jul 22, 2014 | LG Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Found lots of fluff from a previous wash. Next wash the machine failed to empty. Did persist & a trickle of water arrived, machine is now almost empty of water, least enough open the door. Possible...
Mar 15, 2010 | Hotpoint First Edition WMA22 Front Load...
Where does the fluff go when you use the dryer on
The lint should go in the lint trap. If it doesn't go in the lint trap it goes out the exhaust pipe if the lint trap is not installed.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Water coming from soap compartment. is there someway to clean the dryer fluff from machine
It sounds like the water outlet is blocked. Same happened to me.
Unplug machine from mains.
Remove panel located on the rear near the base of machine.
In the bottom right corner you will see the outlet pipe and the pump.
Remove grey outlet pipe to get better access.
Undo the large jubilee clip where the black pipe joins the drum outlet.
Inside this pipe is a white plastic cage filter.
Check to see if anything is blocking it.
Jan 07, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Bosch maxx wfl2260 wont spin or drain
there will be a blockage in your "fluff" Filter cap. i could not get mine open so what i had to do was unplug the washing machine disconnected the filter from the waste and the blockage pipe and the electrics and found a bra wire i pulled it out with some long nosed pliers then the cap came off i cleared it all out connected it all back together and it worked good as new
Oct 11, 2009 | Bosch Washing Machines
Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
