How to fin the remote model for HITACHI C2156MS TELEVISION COLOR
TELEVISION COLOR
4 Suggested Answers
Maciso
  • 125 Answers
SOURCE: my hitachi television
is the red color over the picture like coming out of the picture
or there is a color all over the screen?
thank you
Jose
Posted on Aug 13, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: i have problem on my hitachi prjection television
My father in law had a similar problem it was the bulb to the projector caused the colors to seperate out... like $1500 to replace so he upgraded to a new TV
Posted on Apr 25, 2009
What is the procedure to do color convergence on a hitachi 50vs69a
Almost all you can either get into the mode by use of the remote or remove front speaker grill and inspection plate behind it, there is a tiny blue push switch which will put you in the convergence adjustment mode, then various buttons on the remote do different things and save the adjustments.
Of course if convergence will not adjust you have a bad chip and this model uses two so both get replaced in that case.
Aug 27, 2012 | Hitachi 50VS69 50" Projection HDTV
I just told someone there i lost the instucion maunual for the hitachi clu-4311ug remote i need to know to know what buttons to fix the digital array
post the model number of your Hitachi and I will post the instructions for controlling the array with your remote.
Jul 06, 2012 | Hitachi Televison & Video
Tv is 3D and color is messed up its a Philips projection tv
What you likely have here is a convergence problem and I THINK you will find this model may have actually been made by Hitachi(they made them one year around 2001) and if so it is a better set than the Philips sets.
It depends on if you can do it yourself---If you look inside from the back to the right and see two black IC chips mounted on a large metal sink with fins and they have the STK392-110 number on the front of them----THE SET WAS MADE BY HITACHI.
iF It is a Hitachi set the parts cost will be under 25 dollars total.
Confirm which chips are in YOUR set (they are black,2 1/2 wide and 1 1/2 tall) and I will tell you what is needed.
SD TECH
May 31, 2011 | Philips 64P8341 64" Rear Projection...
I have a Hitachi Model 50V715 HDTV that I believe has a convergence problem, but I want to check to see that it isn't just an imbalance in colors that can be fixed with the remote. I understand that the...
i have a hitachi 46f500 rear projection hd t.v., i get a yellow and blue images i still can see other colours behind, i would like to know how to fix this problem.and if its a part i have to buy let me know thank you in advance.
my e-mail is stambene@shaw.ca
Sep 28, 2010 | Hitachi 50V715 50" Rear Projection...
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Picture is blurry
remove front panel and check the 6 control knobs adjust the intensity of each color as well as the focus of the picture with those colors.be sure to mark the knobs so you can return them to there original position if the set shuts off. Good luck
Jan 28, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 51swx20b
The fin looking things are heatsinks. You'll want to unscrew the chips from them and be sure you have some heatsink compound for the new chips (get it from Radio Shack or a computer store).
I don't have a Hitachi, but I'd guess the other parts you're referring to are resistors. Get yourself a multimeter and measure the resistance of each to ensure they're within tolerance (each one should be marked with a resistance value).
I don't know about the disconnection question. On my Panasonic, the color guns were connected by small connector blocks and easy came off. Be sure to label any connectors you take off to ensure you put them back on the same one. Might want to take digital photos, as I did to help.
Sep 15, 2008 | Hitachi 51SWX20B 51" Rear Projection...
I bought a second hand hitachi tv and there was no remote i want to fix the color
we were given a used hitachi 46UX13k....no real color and so we needed a remote. I went to Walmart and purchased a RCA remote - about $18 that I could program for it. It works, but I am still unable to get color.
Aug 07, 2008 | Hitachi Televison & Video
Remove child lock
i have a beko tv which i want someone should help me find ser vicemode
Jun 16, 2008 | Hitachi 43FDX01B TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
