Question about Dell Inspiron 1440 Notebook
Dell Inspiron 1440 notebook cannot start.
Once i push the power button, its just showing the first Dell loading that have two choice at bottom right corner , f2 for setup and f12 for boot option who seems doesnt work and automatically turn off no matter if i seelect the two option or not... please help me
  • d4rk4ir
    d4rk4ir Jan 07, 2013
    done... Long Generic - Pass .... its seems like my motherboard faulty
    Master:
  • 397 Answers
I have seen these symptoms before when the hard disk drive has failed. It will hand on the POST screen (The part with the DELL logo) for slightly longer than usual due to fault with the drive, after that it will attempt to boot and error from the hard disk so quickly you see nothing but the laptop appear to cut out. Although the hard disk is the most likely thing to be at fault these issues could potentially be caused by any one of the parts within you laptop being broken.
If you are fairly tech savvy try downloading this utility "Seatools" http://www.seagate.com/support/downloads/seatools/ burn it to a bootable CD. Put the bootable CD in you DELL laptop and boot off it, by pressing F12 and selecting to boot from CD/DVD drive. Then run a "Long test" once this test is complete the software will advise you whether the hard disk is faulty or not.
If you are not confident in trying this I would recommend taking the laptop to be diagnosed by your local computer repair business.
Posted on Jan 07, 2013
  • 5 more comments
  • d4rk4ir
    i already take out the hdd and trying to boot with my win7 bootable disc but still not working , is there any chance that it will be the motherboard problem
  • d4rk4ir
    already download it but still didnt know if its will work cause i even cant enter the f2 or f12 even if i press it many time
  • Norwich Repairs
    Norwich Repairs Jan 08, 2013
    You should only have to press F2 (to enter BIOS) or F12 ONCE if you press it at the right time. Wait for the DELL splash screen to appear and then press either one. Don't press it too many times as often on DELL systems and others this will be registered as keyboard fault and the system will ignore all subsequent key presses.
  • Norwich Repairs
    It won't attempt to boot from your Win 7 DVD until you have managed to enter the BIOS or boot menu and request that the system boot from your ROM drive. So we need to overcome the problem of not being able to enter the BIOS (F2) or boot menu (F12) first. Follow the instructions in my previous post and see how you get on.
  • d4rk4ir
    d4rk4ir Jan 08, 2013
    still cant enter f2 or f12... it always turn off automatically....
  • Norwich Repairs
    From what you have described you should be pressing F2 or F12 before it cuts out. On the DELL splash/loading screen as soon as it starts. If you are definitely pressing F2 or F12 before it cuts then I would look at other issues such as your RAM being faulty. A good way to check this (if you have 2 sticks in the laptop) is to remove one and check how the laptop performs. If, after removing one or the other the laptop functions correctly then you know it will have been the RAM at fault and the stick you have removed will need replacing. I would also check your keyboard isn't at fault buy connecting a USB keyboard. If the USB keyboard allows you to input F2 or F12 then you know there is a problem with the laptops fitted keyboard.
  • Norwich Repairs
    If you cannot test your RAM this way because you only have one stick or don't feel confident in removing such components then I would recommend using a bootable memory checker such as MEMTESTx86. However, if you are struggling to get the laptop to boot from CD then you'll be a bit stuck. If that's the case I recommend taking the laptop to you local repair shop to be diagnosed by a professional.
3 Suggested Answers
  • 3940 Answers
SOURCE: How do I boot this Dell Inspiron 1440 in Safe Mode?
F8 at boot
or
MSCONFIG, Boot.ini tab, check safeboot (You will need undo this to boot in normal mode)
Posted on Apr 22, 2010
  • 356 Answers
SOURCE: i turn on my computer
Hi. Try these simple steps: Restart your computer and press F8 when you see the Dell Screen. In the advanced Windows Option, choose Last Know-Good Configuration and press Enter. If nothing happens and you didn't boot to windows, you may need to reset the system back to factory image.
To do that, Do the first 2 steps if you're using Vista. If you're using Windows XP, on the Dell logo, Press Ctrl+F11 to boot from the recovery partition. Follow the instructions to recover system back to factory image.
Hope it helps!
^_^
Posted on Jun 05, 2010
Dell Inspiron 1440 notebook failed to start windows
You probably have a mbr virus. Try this:
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 17, 2012 | Dell Inspiron 1440 Notebook
I have no sound coming from my dell inspiron 1525. There is no tab in bottom right corner of screen. When I get to the relavent download button for a driver, it will not let me download (an error on page...
Go to this page:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
Choose the operating system you are running, then where it says audio, click on it and it will show you the sigmatel audio driver. click on the download button and make sure you download the file to your desktop. After its done downloading then go ahead and run it so it installs on your laptop. Once the system reboots you should get the speaker in the bottom right hand corner and sound.
Feb 06, 2010 | Dell Inspiron 1525 Notebook
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
I use dell inspiron 1440. today onwards the bt travel mouse does not connect to my laptop. how i rectify this problem
reinstal the driver for it and should work or check in start-my computer-right click manage-device manager -action -scan for hardware changes.
Dec 09, 2009 | Dell 5-Button Bluetooth Travel Mouse -...
My dell at atrt up goes to a safe mode choice and
Use your installation CD for Windows that came with your computer, and boot to the CD. (Usually, pressing the F12 key will offer your boot options such as "Boot to CD.")
Once booted on to the CD, it will offer you several options - Do not reinstall Windows - you want to choose the Repair Option.
When the repair stuff has loaded (You may have to select which volume you wish to work on, if so just pick the number that is next to your C drive.) and you are at the prompt that looks like "C:>" you will want to type in the following, without the quotation marks.
"chkdsk c: /r"
It will take a while for it to work all its magic, but that should fix your problem!
When it is finished, you can simply push the power button on your computer to turn it off.
When you next turn it on, it should be happier
Jul 10, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 6400 problem in switching on
hi there so once you see the dell logo keep on tapping f8 and check if you can enter the safe mode, if not tell me the lights because that means thats its a no post issue and we might need to reseat your memory.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 1521 laptop with amd athlon x2 processor does not boot...all it shows me is the dell startup screen.... what can i do?
hit Ctrl and F11 while the blue bar is loading this will start your recovery process. now if there are beep codes then it might be something diffrent your computer will beep once thats normal but if it beeps more times after that you need to post how many count them. right now it looks like your harddrive crashed.
Feb 24, 2009 | Dell Inspiron 1521 Notebook
Dell Inspiron 1440 Notebook Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
