SOURCE: low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
SOURCE: Dynex Te685avr backup battery doesnt work
The sealed batteries in these last about 6 years. You are correct in thinking that you may need a new one. Very easy to install. Here's a supplier of these: http://www.batteryinternational.com/dynex-te685avr-ups-battery-ups-batteries-f1.html
SOURCE: hace a APC XS 900 that said battery needs
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Testimonial: "There is no way to check the water in the batteries as thry are sealed. I found out that after a load is applied it goes on battery for a few seconds "
SOURCE: I have an Ativa battery UPS surge protector model
I have found your user manual here: http://www.apcmedia.com/salestools/KBOK-76HP9K_R0_EN.pdf
It looks like a re-badged APC unit, so the problem is either the battery is dead (probaby likely no matter what) and unable to support the load, or an overload condition is detected.
it is also possible the unit has gone faulty, but without more information I can not be sure.
If the manual does not help or you are still not sure, give me some more information before rating and I will continue to try to help.
