Question about Ryobi RY34440 30cc 4-Cycle Gas String Trimmer Refurbished
I have a 30cc and the line trimmer strip suppled just keeps breaking off after a few revs, replaced it with 2.7 line trim lasts a little longer but still breaking rather than wear out. How do we solve this prolem? Thanks
5 Suggested Answers
SOURCE: Ryobi petrol 30cc Trimmer plt 3043 ye
Hi! With the red know in one hand, push the spool down with th other to the female threaded shaft comes to the top. Then, hold the red know in the other hand with your index finger on the bolt in the middle, holding it down. Now start threading it onto the female shaft COUNTERCLOCKWISE! Once you get it, it get's easier. Good Luck!~Frank~
Posted on Jun 16, 2008
evwood
  • 50 Answers
SOURCE: lawn trimmer line
This is a common problem. Make sure you are using the manufacturer's recommended line. When winding the line, try to coil it in nice even rows. This helps me to get a better feed. Good Luck!
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: ryobi 30cc string trimmer 2230 4y30040b shaft overheating
mike try pulling off the motor and pour oil down the shaft.let me know how it goes
Posted on Mar 24, 2009
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
Maxtra chainsaw parts
We added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them.
Mainly, we just found the problem that solves the start / fuel issues many have had on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
My Maxtra 30cc pole pruner starts ok and runs fine for about 5 mins. The revs then begin to race and the engine cuts out
I have seen this issue before, having trouble remembering the fix though. Is there any more info you can give me about the problem?
Apr 14, 2013 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
I have just bought a Ryobi Expand-it 30cc multi tool 4 stroke. Using it for the first time I filled the oil as instructed, put the petrol in as instructed and then started the machine after 2-3 minutes I...
This may sound like a dumb question, but did you mix the fuel and put it in the machine? If so, you shouldn't have. 4 strokes don't take mixed fuel. You must put the SAE 30 Oil (Not 2 cycle Oil) in a different chamber. Let me know, PLEASE!
Jim
Aug 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Bought new Ryobi P2002P from local home improvement chain, less than 2 wks ago; after assembly and charging battery, I found the .065 string equipped with the string trimmer kept breaking when trying to...
My first choice for a repair is to return this unit to the store, so that they will know that what they are selling is not working.
My second choice is to have you put a good quality line on this trimmer. Ryobi has tried to save a few cents by using a very lightweight line. I have not had a lot of personal experience with battery operated trimmers, but my impression is that they are very light-weight and take significantly more time and effort to achieve the same result as their electric or gasoline counterparts.
Check your owners manual to see if you can use a size .080" trimmer line. Stay with round line. The square or star shaped lines tend to stick to themselves and don't feed well. If you have to stay with the .065" line, find your local lawnmower repair shop and see if they sell a higher quality line.
Good luck.
Oct 21, 2010 | Garden
LIne will not hold
this is not a threading problem.
don't hit anything that is harder than the line you are using, like tree trunk, cement curb,etc.... the trim line is thin, if you want to, you can change the line to a thicker one. that should last little longer.
also, you can take out the line sizer (cutter) from the trimmer cover.
Apr 14, 2009 | Black & Decker String Trimmer Cordless 12"...
Don't know how to rethread the line
Breaking off is a normal process. Set the centre of your line in the spool and wind the two strands in to the Spool, thread and re assemble. C
May 27, 2008 | Black & Decker String Trimmer Cordless 12"...
Ryobi RY34440 30cc 4-Cycle Gas String Trimmer Refurbished Logo
26 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
