Question about Evesham Axis PC Desktop
The system has slowed down considerably since I loaded XP
We got a new hard drive and installed XP. The hard drive is quite fast. One of the most expensive from CPC. Since then the system has slowed down considerably. Question
1) Can I disable part of xp as I only use this computer as home user and internet?
2) I do not know how much RAM I have in the computer. (Serial no WO 00695416. Can you tell by looking up the serial no. in your records
3) If I increase the RAM size will it work faster?
4) If so can you please tell me by how much I should increase the RAM by?
5 How much will it cost me?
  • 70 Answers
Chek the hdd driver as well
expensive hdd maybe need extended driver
chek your hdd sectors too
maybe there any bad clusters in your hdd
and check for your windows too
mybe it's need to reinstall it again
please rate
Posted on Jan 20, 2009
ACER Aspire One D270-1375 notebook too slow, need freeware
No you don't. Those free programs often cause more damage than they fix. Just do the following.
(a) Run Disk Cleanup in Accessories->System Tools. Don't go crazy looking for files to delete unless you know what they are.
(b) Defragment your hard drive. That's something I'd download a third-party program for like Auslogics Disk Defrag or Defraggler because the Windows Defragmenter takes an absurd amount of time to run.
(c) Turn off some of the programs that load at Boot Time. For some silly reason, these netbooks boot with a bunch of programs you just don't need. Antivirus and hardware-related programs stay. Instant Messenger programs, Skype, webcam software, other stuff that doesn't need to run in the background, turn off. (Make sure you only have one antivirus installed because they will conflict with each other!)
(d) Remember, you're running a netbook with an older Atom processor. They just aren't fast.
(e) If you have some technical skills and don't mind spending money, you could consider putting a solid-state drive in to replace the mechanical hard drive it came with. That'll speed it up quite a bit. Don't try it though unless you're comfortable with disassembling your netbook, swapping out a hard drive, and you have the capability to clone your old drive to the new one.
(f) Lastly, try running a complete virus scan on it. Malware can slow down a PC quite seriously.
Post back how it goes!
Jan 02, 2014 | Computers & Internet
Post back how it goes! I posted this twice because you posted your problem twice :)
I have a seagate momentus st94q19a 40 gb hard drive from an old netbook. When I try to install Windows XP, it tells me it can't access the hard drive. Is there any way to fix this or is this hard drive...
see if the BIOS setting for the hard drive is se to IDE. Then, see if there are any jumpers on the hard drive. There should be a diagram on the drive itself that you can follow to place the jumper as Master, or just remove the jumper.
Also, you may want to test the hard drive for surface problems before you make it a system drive. Usually system hard drives go through thousands of read/write cycles that wears them down quite fast, so if the hard drive works just fine as an external USB drive that doesnt mean it will do good as system drive.
Dec 21, 2010 | Seagate Computers & Internet
Hello there: really just looking for some solid advise this hp52w w has the original xp operating system in it with sp2 installed works ok but it gets so slow on the starting windows screen it takes...
Hello Mike, Hi, may I suggest you try first to defrag your hard drive, Im sure when you power on your PC, the hard disk led keeps on blinking, your hard drive may have developed bad tracks and sectors, this slow moving process tends to go forever.
Defragmenting and checkdisk can find faults and bad sectors and tracks that slows down the performance of your PC.
Reformatting should be done if your defragmentation procedure fails to speed up your PC.
Try to run an antivirus program, which may help speed up your PC by detecting viruses, that tends to load forever, or slow down the booting process.
Nov 24, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
It is running very VERY VERY slow. I thought reinstalling windows xp and drivers may solve problem but did not. I booted the system from C drive with windows xp pro in he system. It formats the hard drive,...
You may want to check the hard drive - sounds like it may be starting to fail. When it reaches the point of not continuing does it start to click? If you hear clicking then the drive is having issues and its time for a new one.
Nov 15, 2009 | Dell Dimension 4600 PC Desktop
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
I upgraded the memory from 1Gb to 2 Gb but my laptop's still slow
it can't be, check if the windows is reading 2gb from system under control panel.
to find out if your pc is fast, see if it plays a game faster than before or use a program faster than before
there is no diffrence in using windows itself. example i think in your mind you'd expect to click on my documents and it loads it super fast now with 2gb of ram? no, you're wrong weather you have 1gig or 2gig windows still works the same
the diffrence is Faster file transfer, faster applictions but not a faster windows.
it could also be the norton if you installed, it lowers your speed.
check Task manager, in the performance section
cpu usage should be under 10%
and pf under 500mb
Mar 03, 2009 | Toshiba Satellite M55-S3512 Notebook
Hard Drive
Yes this hard drive should work with your system. all you should take into consideration is whether the inputs and such are the same and if all the other components in your system will support the newly added part.
Jul 13, 2008 | Computers & Internet
Computer running very slow
win xp required more then 256 mb ram
mcafee antivirus make system slow,
it take more ram
so u remove antivirus & also
go to run give msconfig
then remove start up items.
for more information call me +919985064600.
avast anti-virus is better it's do not make slower & also norton.
Mar 16, 2008 | Microsoft Windows XP Home Edition
Evesham Axis PC Desktop Logo
66 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
