Question about Averatec 4200 Notebook
There are lines running through the screen and I was wondering if there is a fix for this?
    Master:
  • 397 Answers
There are 3 main issues that can cause this:
First I would determine whether your GPU is at fault as this is the easiest thing to isolate. You can do this by plugging into an external monitor. If the lines are still there on an external display you can be fairly certain your GPU is faulty. In this case I would recommend getting the GPU of the laptop re-balled or replacing the mainboard completely. Unless you have a separate graphics card in the system such as MXM, then just replace that or get the GPU on that re-balled.If there is no distortion of image on an external display then you have isolated the problem to the screen panel or LCD cable of the laptop.
Secondly I would check you LCD cable is seated correctly. If not re-seat and test. Hopefully this will cure your issues. If this doesn't cure your issues, while the laptop is running try to flex/bend the LCD cable and see if you see a change in the distortions to the image displayed. If you do, you probably need to change the LCD cable.
Thirdly if you have got the stage where you have tried flexing/moving the LCD cable while the laptop is running and the action causes no change in the distortion of image it is most likely that your LCD panel has a problem and needs replacing.
Hope all this helps :)
Posted on Jan 07, 2013
I have a 47 inch sanyo lcd tv and the screen is broken in the lower right hand corner i want to know how much it will cost to fix and i dont want it will be cheaper to buy a new one
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
Jun 02, 2010 | Sanyo DP32746 32 in. LCD Television
Vertical line on my Compaq Presario C700 Screen
maybe you have death pixel's
or your screen have break any stuff that it his made
May 18, 2009 | Compaq Presario C700T Notebook
Flickering Screen/Line in Screen
flickering is a sign that bulb will go out soon. Also check if the bulb fan is clean and running.
Mar 22, 2009 | Akai PT46DL10 46" HDTV-Ready Television
White vertical line going through my IMAC screen
The line is an indication that there is a failure in the display, most times the failure will be limited to the line you see but occasionally the problem will spread, causing more lines. the only way to fix it is to have the display replaced.
Dec 15, 2008 | Apple iMac G5 Desktop
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer menu...............you can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Sanyo 27" Problem: Fuzzy Screen
sanyo does this alot it is either you need to replace your tuner or you have two resistors 220k ohm s that need to be replaced.this will fix your problem.if repair cost is cheaper to fix then buy a new one its up to on that one!
Dec 01, 2007 | Sanyo DS27910 27" TV
Averatec 4200 Notebook Logo
32 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
