Question about Toto Ms874114sg-01 Carlyle Toilet With Seat Cotton
Laufen toilet .seat will only go down when pushed down .top slams down
3 Suggested Answers
pipesster
  • 20 Answers
SOURCE: THE WATER KEEPS FILLING PAST THE OVERFLOW.
Replace fill valve. Fluidmaster works quite well and is very adjustable.
Posted on Jan 25, 2010
  • 31 Answers
SOURCE: How do I adjust hinges on a soft close toilet seat
it does this get used to it.
Posted on Apr 11, 2010
Laufen Paloma toilet seat loose
Check the nuts and screws in the tank side of the seat.
Feb 02, 2017 | Home
Why does the flap close before water flushes
the flapper is pushed down too far on the vent tube. leave about 1/2 inch of space between the bottom of the flapper flange when you seat it over the vent tube. make sure the flapper is level. if the flapper is too close to the bottom of the vent tube, it will slam shut before the flush is finished.
Jul 24, 2014 | Fluidmaster Duo Flush Toilet Kit
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
Pacific toilet parts
If your talking about the Laufen Pacific Toilet the flush mechanisms were either DAL Manufacturing Or Geberit Manufacturing the seat was made by Pressilit.
Oct 23, 2013 | Home
My slow close toilet seat now slams shut. Are there any adjustments I can make to correct this problem?
WOW! Slow-close toilet seats. What will "they" think of next, to pick your pocket?
Slow-open mechanisms such as cassette players and top-loading DVD players use a special type of grease to achieve that effect.
The screen on the laptops uses a friction mechanism based on a "clutch-spring" with enough holding power to keep the display in the position selected.
This "clutch-spring" is factory adjusted so it neither slips under the weight of the laptop screen, nor is so tight that extra force is required to close the laptop.
These things do wear out, and as a rule are not user serviceable.
Can you adjust it? Good question!
Can you adjust it so it works? Ahah!
My rule of thumb: If it's already broken, how much more broken can it get?
Therefore, my conclusion is that the toilet seat's slow-close mechanism is factory set at the point where it will neither slam down nor stop half-way, but glide down gently until it's closed.
An interesting added feature would be for the toilet to recognise who's about to use it, and for what, select the seat position be it up or down, and then regulate the water volume needed to flush.
Also, it could flush itself once the lid is fully closed, to avoid or minimize the dreaded "toilet flush mist". arrrghhh!!!
Jul 04, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
The slow-lowering lid has reverted to slamming - can i just tighten the bolts to fix it?
If you want to be able to just tip the seat and let if fall without that loud slamming clank, look into getting some Drop-a-Seat cushions, a brand new product that is only $4.99 and absorbs the fall of the toilet seat and eliminates loud clanks. They're non-absorbent, have an easy stick-on installation, and are permanent but removable. www.drop-a-seat.com
Feb 24, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
Toilet - replacing a wax seal
No when you put the toilet on a new wax ring you need to push the toilet down to the floor to make a good seal. You will be fine just put some waight on top of toilet to push down wax.
good Luck
Oct 18, 2009 | American Standard 5322.011.173 Rise and...
The self-lowering mechanism of my Laufen Pro toilet seat is broken, how can I fix it myself?
The pneumatic cylinder that controls the lowering probably needs to be serviced or replaced. Here is a link to the manufacturer website:
http://www.laufen.com/export/servlet/portal?codpage=productsresult&planguage=EN&ppais=EX&sesid=2302425382030&tipo=3&dlvalue=01A1&psgvalue=0008&dltxt=LAUFEN+PRO&psgtxt=WC-SEAT&radio_ch=&designline=01A1&productsg=0008
Mar 27, 2009 | Home
Toto Ms874114sg-01 Carlyle Toilet With Seat Cotton Logo
54 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
