Question about Sony VAIO VGN-NR220E/S Notebook PC
NO BATTERY DETECTED - Sony VAIO VGN-NR220E/S Notebook PC
    Master:
  • 397 Answers
First of all, try removing the battery. Hold the power button on the laptop for about a minute while it is disconnected from the mains and the battery. The re-insert the battery. Hopefully it will charge now. If not I would recommend trying a replacement battery.
Posted on Jan 07, 2013
What does no battery is detected mean ?
ur battery may be dead, try with a friend battery and check
Jul 02, 2014 | Dell Vostro 1500 Notebook
No battery is detected
If the battery is dead, it will not be detected.
Mar 18, 2014 | Acer Aspire Computers & Internet
No battery detected
LOL, good ole Vista. I would never discharge my battery once I got it charged. I know the instructions say that, but I just never do it. Sounds like your battery is defective. Send it back.
Apr 08, 2012 | Computers & Internet
My Acer 1681WLMi stopped recognising my battery after Windows 7 32bit was loaded. No battery detected) The computer works fine on Win7 with the AC power adapter plugged. But within 2-3 minutes of...
Please switch off the laptop and remove the battery. wait for 10 minutes and clean the battery and keep it in laptop. Connect the laptop to AC power.
Try to check whether the battery is detected in the BIOS setup.
If the BIOS is not detected then please exchange with the new battery from vender.
Jun 06, 2011 | Acer Aspire 1681WLMi Notebook
Is there a list for computer codes for 1980-1990's Chrysler Le Baron
Yes here is that list.
Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
Part 1: Chrysler Domestic vehicles
CODES/Meaning
88 display used for start or test
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle positioner sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 wastegate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects overboost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eeprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
May 31, 2011 | Chrysler LeBaron Cars & Trucks
My dell latitude says no bootabble devices and no drive what should I do to fix this
Dear sir...
3.remove the battery first,then press the on/off button 20 seconds.then replace the battery.
--------------------------------------------------------------- Check the hard disk is detected in the BIOS(follow the below steps)
1.on the laptop,immediately press Del. (F2 or Del or F10 these are common to display the BIOS setting)
2.Check the menus one by one whether the hard disk is detected or Not detected.
if the hard disk is not detected then remove the battery,remove and replace the hard disk .(See the laptop manual) -------------------------------------------------------------------------
if the hard disk is detected then set the BIOS with Basic Default configuration.
press F10 Press Y Press "Enter"
All the Best sir... Thank you........
May 16, 2010 | Dell Latitude C510 Notebook
No battery detected reading on my toshiba laptop
If the laptop was purchased new in November, 2008, the laptop is still under warranty. So, contact Toshiba for repair or replacement.
If not purchased new in November, the battery would probably need to be replaced. Hope this helps.
Aug 06, 2009 | Battery Technology for Toshiba Satellite...
Nokia 6300 cannot be detected by my computer when
The PC seems to be OK. The phone switches off and hence can not be detected. You cant detect a dead device. Try a different battery. Or try using the charger while connectiong. If it does not go off then the battery is at fault. Change it. If nothig is detected faulty, then uninstall PCSuite . Restart the PC and re-install PCSuite without connecting the phone. When you connect the phone afterinstalling the SW, he phone will be detected immediately.
Aug 05, 2009 | Nokia 6300 Cell Phone
Bought a new battery and it wont charge, says on AC power
Take the Battery back Its defective , New batteries should charge for 18-24 hours, and the computer should tell u that it wont run till the battery is fully charged.
Jul 22, 2009 | HP Compaq Presario V2000 Notebook
Wrong battery detected.
hmmm..interesting....you may need to download the system drivers, usually for bios or other utility programs. the compatibility issue with batteries, is based on the make/model being loaded into the listings from the sysadmin for your operating system.
www.hp.com
Feb 25, 2008 | Compaq Presario R3000 Notebook
Sony VAIO VGN-NR220E/S Notebook PC Logo
158 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
