Question about Canon Rebel XT / EOS 350D Digital Camera
My Canon Rebel XT was recently used in cold weather and left in a car for hours ( 4 degrees). Now, with a fully charged battery, it won't power on. Any ideas as to what the problem and solution is?
    Novelist:
  • 164 Answers
It seems tha moisture got in your camera and affected it.
If won't power one, then such symptom indicate a malfunction on the DC/DC voltage converter circuitry, and the camera has two of them located in different boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing tgo open it and perform some basic diagnostics of the failure. You will need tools to do it, which includes the usage of a soldering iron.
Best regards,
Posted on Jul 25, 2009
My rebel t3i wont turn on!!!
I just bought a T3i and only used it 2 days of shooting. On third day, it's not turning on and it's 80 degree's. So not cold weather. Batteries are fully charged. When I put batter in and turn the switch on, the red light comes on for only a second and then nothing! Other times the red light won't even come on, period. As I said, I've only had it 3 days and it's dead....
May 06, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Haven't used my Canon rebel xt for awhile but tried today and it will not turn on. Purchased new CR2016 battery and fully charged the other battery. Has not been dropped or misused. Please help
Aposta,
It is possible if you haven't used the camera for a while that the contacts inside the battery compartment need to be cleaned. This can be done with a q-tip and some alcohol.
Thank you.
Mar 21, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Battery life has shortened considerably, whats the problem
Batteries lose capacity with age. Eventually they fail altogether. Might be a good time to get a spare.
Canon say this camera gets about 600 shots per charge at 68 degrees Fahrenheit, dropping to about 450 at 32 degrees, so cold weather can be a factor. Also using the flash a lot can reduce the number of shots by a third or more. As winter approaches, both cold weather and more frequent use of flash are likely (gets dark earlier).
Oct 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Eos flash
Been there done that. The pop up flash seems to be the weak link on this camera. Make life easier for yourself and get much better results for flash pictures - buy a Canon speedlite. Look on ebay.
Mar 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera will not function
Try a new battery in the camera, if that does not work, decide if the camera is worth sending to canon to see if they can work out the proublem. Though this is likely to be costly, you maybe better of buying a new camera instead.
Jul 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
