Question about Watches
Put together this Geneva watch clasp that came apart
I've had a similar thing happen before and it was a $10 fix at the watch repairers, so I have the same advice as Conjurer.
Posted on Jan 07, 2013
4 Suggested Answers
charcois
  • 763 Answers
SOURCE: kennith cole reaction watch
try to change your settings of your clock by getting it full circle to get back to real time and see what happens. if still problem persist then you might send it to repair service or it should have warranty service for an expensive watch. hope that helps!
CHARCOIS
Posted on Oct 01, 2008
SOURCE: geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
Posted on Dec 10, 2008
SOURCE: Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Posted on Dec 26, 2008
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
How to remove links from band
This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
Sep 22, 2009 | Festina 16177-4 watch Watch for Men
I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
Sep 19, 2009 | Watches
Apr 24, 2008 | Tag Heuer WK1111BA0317 wristwatch
Geneva watch bracelet
Apr 01, 2008 | Geneva J06345 Wrist Watch
Missing hinge pins
You will have to get a complete clasp assembly, which will have to be ordered from the factory that makes that model. If the clasp assembly is not available, A jeweler might have that part or be able to repair it for you.
Mar 06, 2008 | Field and Stream FE6BI Wrist Watch
I cant open my brand new watch ...HELPPPPPPPPPPPPPPP!
I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
For any hidden clasp band, see this web page (excerpt below):
Refer to the "Hidden Clasp" diagram and follow the instructions under the diagram:
cad9c3e.jpg To open this clasp, reach under the bracelet band and lift upwards. The band extends to allow for easy removal.
Jan 09, 2008 | Movado Kardelo 0605479 Wrist Watch
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
