Question about Radio Communications
Can i connect an antenna, lets say 200ft in the air to motorola FCC ID:K7GMJBGJ
K7gmjbgj hand held walkie talkie
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
It is Possible, but not recommended.
By the way when you post a query, always Give the following info:
Make & Model of your radio
Giving the FCC ID is of no value here.
Cheers,
Peter
Posted on Mar 06, 2013
3 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: I have 4 motorola walkie talkies but no
The Motorola GP340 radio is a dealer programmable radio. It requires a cable, radio interface box and Motorola proprietary software (which is available by subscription to dealers and qualifying entities).
Posted on Oct 13, 2009
  • 4 Answers
SOURCE: walkie talkie symbol stuck on cannot remove it
In order to reset the radio, power on while pressing both volume buttons (+ and -) together with the PTT (speak) button, until you year a high-pitched tone.
But I have found that the "stuck on receive" problem is related to the battery voltage: non-rechargable AAA or incorrectly charged batteries can give 0.2-1.0V above the nominal voltage. Try to leave the radio open for a few hours or replace some of the four AAA batteries with slightly exhausted ones and see if that helps.
Posted on Sep 19, 2012
I need instructions on a Motorola walkie talkie FCCID K7GSX900
Go to the following web page and download the manual: http://www.manualdisk.com/pdf-/motorola-walkie-talkie-fcc-id-k7gsx900-range/
Mar 04, 2015 | Motorola Radio Communications
WHERE CAN I BUY ONE
Check ebay, search TalkAbout T8500.
Best regards.
Oct 16, 2014 | Motorola Walkie Talkie 2-Way Radio
Fcc id k7gmhbcj
Most replacement batteries for the TalkAbout line of radios can be found at http://wirelesspro.com/
Best regards
Jul 16, 2014 | Motorola Walkie Talkie 2-Way Radio
Fcc id k7gmhbcj
Be sure the "Channel" and "Code" settings are identical on both radios.
Apr 18, 2014 | Motorola Radio Communications
NOT WORKING 2 WAYS ONE SET SEND AND RECIVE ANOTHER ONE ONLY RECIEVE MOTOROLA WALKIE TALKIE fcc id k7GSX900 UPDATE
Check your programming. It is possible one of them has a different PL (aka code or interference eliminator code) than the others. Here is a link to the user guide page where you can select your model from the pulldown. http://shop.giantintl.com/Manuals.asp Look at the section about programming and turn off any special features, taking your radio back to a very basic mode, matching all setting between the radios. This should make your radios communication easily together. If not, you may have one bad radio in the mix.
Best regards.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
Not recieving voice on FCC ID K7GSX900
Be sure the channels and codes are set identically on both radios.
Nov 06, 2012 | Motorola Walkie Talkie 2-Way Radio
Vhf 340 walkie-talkie radio you cannot transmit but you can receive effectively. I open the radio but no sign of any burn.I try the radio in all the channels is the same response. thanks. we use them in...
You may have a bad antenna. What happens is a lot of guys carry their radios around by the antenna, inside the connection to the antenna is weak and can crack at the solder joint, thus opening up the antenna circuit and prevent you from transmitting any power out. Our Motorola hand helds have this problem, they are weak at the antenna connector and guys swing them around by the antenna end up breaking them.
Your next problem is that if the radios have been used often enough with a faulty antenna circuit, your final amplifiers are probably toast from transmitting into an open antenna circuit, causing all the power to be reflected back into the radio and burning out the final amplifiers
Sep 15, 2009 | Motorola Walkie Talkies 2-Way Radio
Radio Communications Logo
207 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
