Question about Nikon Coolpix 3200 Digital Camera
No images on card but no memory
As of a few days ago, I had around 150 images (around 600K each) on the camera. I uploaded and deleted them and started over today. After 20 images (around 600K each), it told me it was 'out of memory.' I uploaded and deleted them. Now it still says it's 'out of memory' but it also tells me there are no images on the card. How can it be out of memory with no images stored on the camera. I'd be most appreciative if anyone can help!!!
  • 432 Answers
You need to format the simm memory card. Your camera can format the memory card. If you have the user manual it should tell you how to do this.
Posted on Jun 30, 2007
SOURCE:
What does out of memory message mean on my nikon coolpix camera?
You have two questions here. Out of memory could mean that your memory card is full and you cannot take any additional pictures until you either replace the card with a new one, or delete or reformat the card you have in it. It could also mean that your card is "locked". Check for the little toggle switch on the side of the card to be sure it is in the "unlocked" position. Or it could mean that you do NOT have a memory card in the camera at all and you're using the very small internal memory your camera comes with (it usually will only hold about 4-5 images. If this is the case, put an external memory card in the camera.
The second part of the question deals with uploading to your computer. There are a whole host of reasons that can cause this. Here are a few.
1. Your software is configured incorrectly. It might be set for only a certain type of image (jpg, RAW, TIFF). It might be set to accept duplicate images and your images are already uploaded (somewhere on the machine).
2. It might be that your cord or connection is defective.
3. It might be that the computer is trying to find the external memory card and you don't have one.
4. You software might be looking for videos instead of images. Check your software configuration to be sure its set for image upload.
5. Be sure your battery is fresh. Some cameras will not upload with a weak battery.
6. The camera or software could be defective.
Aug 09, 2014 | Nikon COOLPIX Cameras
I have a 4G Sandisk memory card which is compatible and still keep getting file contains no image data
The memory card was setup for your old camera. Try formatting the memory card using the Nikon camera's Menu settings.
Apr 06, 2013 | Nikon COOLPIX S4200 16MP Digital Camera...
Retrieve deleted photos from a sdhc card
You may try steps below to recover pics from sdhc card
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download card recovery software, recommended one is asoftech photo recovery (simply because i was using it and it worked)Memory card recovery software
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Sep 04, 2012 | Cameras
Sanyo camera vpc S880 digital recover deleted pictures free
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this photo recovery software
http://www.facebook.com/pages/Asoftech-Photo-Recovery/126127714100611?sk=info
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Jul 22, 2012 | Sanyo VPC-S880 Digital Camera
Coolpix s6100
Format the memory card. Make sure your format the card each time you finish uploading your pictures to your computer, instead of simply deleting pictures.
If you can't format the card, try another card.
May 11, 2012 | Nikon Coolpix S6100 Digital Camera
Olympus 790SW 7.1 MP reads full 1GB memory card is full after 2 pictures
Suggestion is to format the memory card and permanently delete all of the images from it. The card should then be able to be reused and you can start taking images again. To format the card go to Menu - setup and press ok - go to format and press ok - go to yes and press Ok. This will clear the card and you are back in business.
Oct 03, 2008 | Olympus Stylus 790SW Digital Camera
Communication error when uploading pictures on computer
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
Aug 10, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
No images but no memory left
do you have a mac? when you delete anything off a flash disk from a mac, it puts them in a hidden folder (the mac recycle bin) either connect your camera to a mac and empty the pictures from the recycle bin or use the view option to view hidden files and folders. you should see everything there. if this camera has never been connected to a mac, i don't know. try formatting the card. there are many guides on the net, much better than i could type. let me know if it works! b.dale.flat "at" gmail.com good luck!
Jun 30, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
75 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
