Reset UNI1BEST UNI-2082 Fingerprint scanner - Office Equipment & Supplies
SDK of Uni1best uni-2082?
Posted on Dec 10, 2014
Biometric fingerprint scanner acer
That is because it has not been removed from User Accounts.
Dec 29, 2013 | Acer TravelMate 8371 Timeline (LXTTD03077)...
Dvr password reset
see hte following link below. you need to set the DVR back to default in order to reset the password.
http://www.safe-n-secureinc.com/Support/Samsung/Samsung%20SHR-2160-2162-2080-2082-ENG.pdf
Nov 06, 2013 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Hp envy of unlock passeord
Which operating system ???
CMOS (Complementary metal oxide semiconductor) refers to the battery-powered, semi-conductor chip located on an HP computer's motherboard.
It is where the BIOS stores important information regarding the PC's system configuration. CMOS is required for an HP laptop and its hardware to run stably.
Sometimes, however, it is necessary to clear CMOS, such as if you lose your BIOS password or your BIOS is corrupted.
Clearing CMOS on HP laptops varies depending upon the model, but for a lot of laptops, the process simply requires removing the battery for a short period of time.
Power down your HP laptop. Remove the AC adapter and any other peripheral devices. Turn over the computer so that the bottom side is facing up.
Ground yourself, either by touching a piece of unpainted metal or by wearing an anti-static wrist-strap.
Locate the battery. This will vary depending on your laptop's model, but it is usually located on the back, near the rear of the laptop.
Review your laptop's documentation to find the battery, if needed.
Many newer models require that you remove the battery by releasing or holding down one or two latches, then gently pulling the battery out.
Some models may instead require that you unscrew the battery from its compartment.
Leave the battery out of the compartment for at least 30 minutes.
Do not attempt to turn on the computer and do not touch the battery within that time.
Some HP laptops may require you leave out the battery longer to clear CMOS, others might take only 10 to 15 minutes to reset.
Ground yourself, then put the battery back into the HP laptop.
Snap the battery latch into place or screw the cover back on, if necessary.
Removing a Bios - CMOS Password
http://www.dewassoc.com/support/bios/bios_password.htm
Disable Fingerprint on an HP Laptop
Many HP laptops include a fingerprint scanner to enhance the security of your computer.
When the fingerprint scanner is enabled, the computer requires a fingerprint scan to log onto Windows.
Disable the fingerprint scanner if you do not need or want this feature.
With the fingerprint scanner disabled, you can log on to Windows using a password.
You can enable the fingerprint scanner anytime you need to.
Access the Device Manager on your computer.
Select "Control Panel" from your computer's Start menu.
Click "Hardware and Sound" and then click "Device Manager."
Find "Personal identification devices" in the "Device Manager" list.
Click the "+" sign next to "Personal identification devices."
This opens a list of all of your devices.
Click on "Validity Sensor."
Select the "Driver" tab at the top of the properties window and click "Disable" to disable your fingerprint scanner.
The button changes to "Enable" and you can enable the fingerprint scanner at any time.
Click "OK" to exit out of the window.
Jun 27, 2013 | Computers & Internet
What is the cost of the 4000 fingerprint sensor
the cost for 4000 fingerprint sensor is $75.99 without shipping
Nov 07, 2012 | DigitalPersona U.are.U 4000 Fingerprint...
I bought a hamster fingerprint scanner, i installed it and it scanned offline but it couldn't connect with the website i want to use it with, all it shows is no scanner connected while it is
bought a hamster fingerprint scanner, i installed it and it scanned offline but it couldn\'t connect with the website i want to use it with, all it shows is no scanner connected
Dec 11, 2010 | SecuGen Hamster
I have H P Pavillion DZ6500 which I just upgraded to Windows 7 Professional. The Verisoft Access Manager that drives the fingerprint scanner is not compatible with Windows 7. Any suggestions?
Hi:
I fought the same thing with another fingerprint scanner, and even spent some quality time speaking with Micro Soft Technicians....It seems they are not really supportive of fingerprint scanners,And forget getting any support for Window 7, 64 Bit version. My fingerprint scanners were Microsoft brand, and still no 64 bit support...
Nov 24, 2009 | HP Pavilion tx1000z Notebook
Fingerprint reader
have you reinstalled the driver? if you reformatted the OS then all the drivers would have been deleted
Sep 21, 2009 | Office Equipment & Supplies
Problem resetting Biometric fingerprint scanner Sony Vaio VGN-SZ360P
Yes, you need to try to locate the program folder and attempt to delete it. or you can use the KillBox program that will force delete the program. If you would like that send me a email jcamphelp@hotmail.com and I'll send that to you....
Oct 27, 2008 | Computers & Internet
Which Toshiba Satellite models include fingerprint reader?
I have a Toshiba Satelite U305-S7647 that has the Fingerprint Scanner - No Face-recognition, though..
Jun 03, 2008 | Computers & Internet
Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Jan 22, 2007 | HP iPAQ H5450 Pocket PC
275 people viewed this question
k24674
