My capslock indicator doesnt work. Im unable to identify whether it is turn off or on?
  • 32,281 Answers
When you press a key you can see if the letter is uppercase or lowercase.
Posted on Jan 07, 2013
  • Basanta Jan 07, 2013
    Exactly, before re-installing the windows the indicator used to be seen on the screen. but now only the num lock indicator is seen on the screen. Please help
  • Chris Hingee
    Chris Hingee Jan 08, 2013
    When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator..
Which wire from indicator switch goes to flasher relay im using a narva 2 pin flasher relay in a 2002 holden rodeo one positive from battery an wht colour would it be from the switch or is it 2 wires
There could be no relay in the vehicle because it doesn't need one. CANbus vehicles tend to use a single module to carry out all the vehicle timing requirements - indicators, hazards, wipers, courtesy lights and so forth.
If the flashers don't work it would be better to repair the system than to rewire and use an outdated method, perhaps introducing further fault codes that might affect the operation of other stuff.
A little used hazard switch is a common cause of flasher failure...
If you really must rewire the system, the (ignition) live, as you say, goes to one side of the flasher unit and the other to the centre contact of the indicator switch though you will need a wiring diagram to identify the colour. There is no single universal colour code though if I was looking at an old British car I would expect to see a dark green wire with a thin black trace line.
A wiring diagram will be useful also for identifying the wiring to the lamps and separating the hazard switch wiring from the circuit. If there are two dashboard tell-tale lights the 2-pin relay will be ok but if there is only one you will need a 3 or 4 pin unit depending on whether electronic or electro-mechanical.
Jun 26, 2016 | Holden Cars & Trucks
Why doen't my password work when I log in?
Check your capslock is 'ON' or check whether capslock is ON while you creating password.
Jul 28, 2015 | Computers & Internet
Cap lock download
Some Keyboards have the option to display capslock on screen. To check if you can, try this
  1. Open Control Panel. In Windows 8 you can access it by right clicking the bottom left of your screen, and clicking Control Panel.
  2. Double click Keyboard. The Keyboard settings panel should pop up.
  3. If you see a Keyboard Settings tab near the top of the panel, click it, and see if there is an option to display Capslock on screen.
You can try this 3rd Party software :
CAPSLOCK Notifier 1 1
Alternatively, Dell provides a driver to display capslock on screen, however it is for a different keyboard model, so I am not sure if it will work with yours.
http://ftp.dell.com/FOLDER00703639M/6/APP_IO_W7_A00_Setup-YPN75_ZPE.exe
Apr 10, 2014 | Dell Inspiron One 2020 All-in-One Desktop
Whenever I press the NumLock button, it does a sticky key-type beep and the green LED comes on but I am unable to use the keypad still. The same thing happens with the CapsLock key but I am able to use...
Hello
In control panel/keybaords. Disable sticky keys.
Or clean the keyboard with some windex and a rag,try turning it upside down and lightly tapping it to remove dust and dirt.
Jan 08, 2011 | IOGear GKM502 Keyboard and Mouse
Capslock and num lock led continous blink and blank on screen
Heres a simple fix that seems to work. Wrap it in some towels for a while (about an hour). It should turn itself off due to overheating. Unwrap it and let it cool off for a bit. Turn it on and see if this worked. Its worked on two of my hp systems. Im no longer buying from hp. Recommended brands are asus lenovo or acer.
Dec 18, 2010 | HP Pavilion dv6000z Notebook
I was carrying Dell vostro 1510 laptop in my bag duringmy bike ride for about 100kms. when i tried to switch it on after that, i am not getting any display rather the capslock, scroll lock indicators are...
Turn it off, remove the battery and put it back on. If that still does not work, remove the battery and attempt to turn it on with just the ac adapter connected. If it turns on then you need to replace your battery. If you still have problems you can try a different ac adapter from an electronics store or a computer shop. If it still does not work, then the problem may be internal, possibly the dc jack. Let me know how this turns out.
Aug 26, 2010 | Dell Vostro 1510 Laptop
The laptop turns on and then the locks the numlock and capslock turn on and stay on and nothing else
press shift+function key first if that doesnt work have someone check your on qwerty keyboard
Dec 13, 2009 | Dell Inspiron 1501 Notebook
Cigarette lighter(more info)
how about checking the fuse and wiring to lighter
Jul 10, 2017 | 1999 Toyota Camry
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
