Question about Konica Minolta Seal for Bizhub 500 420 363 362 C360 C200 MC8650 MC8650CK - 4348311712
Hello sir i have a konica minolta bizhub 500, sir the actually the problem is that, the roller F2 is not accepting paper that is way the error is generate and after some time its properly working. i don't understand what is problem plz help me.
  • Konica Minolta Master
  • 1,294 Answers
Clean the paper feed rollers and verify the actuators and sensors in the paper way.
Posted on Feb 05, 2013
2 Suggested Answers
  • 20 Answers
SOURCE: hello sir i have a konica minolta bizhub 500, sir the actually the problem is that, there is no misfed paper in lower guid plate FN1,FN2,FN4,FN5,FN6..but the error is not remove from the display and m
There might be a small piece of paper that was stuck out out of your eyes reach, try to brush it away with a paint brush, air blowers and compressors will also do the job, as there might also some dust that block the sensors.
Posted on Dec 11, 2012
I am having L code errors on our Konica Minolta Biz Hub 363
Sir/Mam,
#10 Transfer roller needs replacing sponge looking roller right side of the of the machine when you open to remove paper jams.
# 9 Developing unit needs replacement that the part that holds the drum and developer/toner. IF YOU YANK THIS UNIT OUT WITHOUT REMOVING THE LITTLE COVER ONE BOLT and DICONNECT THE CONNECTOR. BIG TROUBLE, going to cost a lot to repair.
#8 PAPER DUST REMOVER the device that collect paper dust yes paper does produce DUST. Just before the sponge roller
#6 IS Warning that the developer has not been replace inside the drum cartridge. SEE #9
#4 Drum need to be replaced.
Really have to watch for all of that sir/mam.
Apr 11, 2014 | Konica Minolta "Minolta Bizhub 363 Copier,...
Misfeed detected
have the rollers been replaced, misfeed means the rollers cant grab the paper not a JAM
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub 600 konica minolta
it could be the Fixing unit, or an electrical card (PRCB)
Nov 11, 2013 | Office Equipment & Supplies
My problem is with a bizhub 181, because the copies are opaques. I already check and replace the imaging kit. but is damaged.
Sir/Mam,
Is the machine set up as a printer also do print come out ok? Copies from the big glass ok? Mite be the electrical connection to the sponge roller on the right side door the sponge looking roller is what helps the transfer of the image off the drum to the paper. The paper is guided between both the drum and that sponge looking roller to place the image on the paper. There is a high voltage applied to that roller during the copy cycle. the connection for the roller is on the copier at the rear where the right side door closes
Oct 05, 2013 | Konica Minolta 950-281 Genuine Konica...
Bizhub500
replace center sensor or use reset in the sofware mode
Apr 24, 2013 | Konica Minolta Bizhub 500...
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
Km 200 Paper cannot pick up. error paper misfeed
please check if the pick`up rollers are dirty, if so clean them with Platenclene, and check if they are spining, if not call for a tech because one or more clutch`s are faulty.
Jun 03, 2011 | Konica Minolta Bizhub-200 Minolta Printer
Toner fly in Bizhub 500
The problem may be comming from the drum unit, there is a small over sray tray right under the developer mag roller. It is mostly filled up with waste toner or dropped toner from the mag roller. You have to take out the drum unit and then the opc drum and vaccum out the tray and that should take care of the problem for now... The problem will come back..... Have you ever had the developer and or the drum & blade replaced. Minolta are a duel component copier. When the developer is worn out it will start to trow toner and fill up the small tray under the dev. mag roller..... Good Luck
Jan 18, 2009 | Office Equipment & Supplies
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Konica Minolta Seal for Bizhub 500 420 363 362 C360 C200 MC8650 MC8650CK - 4348311712 Logo
172 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
