To protect the wire of my earphone, how? - Audio Players & Recorders
    New Friend:
Why don't you wind a piece of clothes to it, I tried this:
http://happylifetips.net/Unique-colorful-earphone-cover.html
Posted on Jan 07, 2013
Testimonial: "thanks!"
Protection Message
Protection mode is a shutdown to protect the circuits on the amplifier. This will come on if the speaker wires are shorted or if their is a lot of DUST on the inside of your machine. On some machines, protection mode will come on if one of the speakers is open (breaks). What I would do is check the earphone jack on the tv. Put a headset in and see if that works. Last resort is purchase a can of air duster.
Jan 13, 2014 | LG HT356SD Region Code Free Home Theater...
Tip
How to protect the thumbsticks on your xbox 360 controllers
Just use the the protective foams from your old earphones. If you want to take care and prevent the thumbsticks from breaking or chipping, just use the foams from your old earphones.
on Sep 15, 2010 | Video Game Consoles & Games
Can i listen to fm radio without using earphones?
It will be depends on your mobile brand....
Jun 30, 2011 | Cell Phones
Whenever i plug my earphones into my mp3 player I cannot hear my music through the earphones. any idea what the issue could be?
The wire inside the earphones Tore. If these earphones came with the Player then they are probably not very strong earphones. Usually the name brand ones are more durable. I believe it is time for you to buy some new earphones.
Dec 29, 2010 | Philips GOGEAR SA6045 MP3 Player
My phones right earphone is not working.
The problem is obviously as a result of the fact there is a loop in the wire as a result of a breakage in the wire hence the right earphone is not working.
The solution is to replace the wire that connects to the right earphone,or better still get another earphone.
Thanks and take care
Dec 04, 2010 | Cell Phones
Wire disconnect from left earphones
Time for some ingenuity.Disassemble the housing to get to the wire connections.The solder pads where the wires go are usually marked + or minus(-). The white/colored wire(signal) goes on the + side.This could be a red dot. The other wire (black) goes on the other pad(-). These wires are so fine they sometimes use nylon thread to give it a lil strength.Good Luck! dnbbgy
May 30, 2010 | Bose TriPort Consumer Headphones
Earphones wont work on dell computer/vistas have to restart computer to go from sound to earphones . how do i fix this
first check you connected the earphone properly. earphone has two wire. connect earphone green wire where you connect the speaker.
Jan 22, 2010 | Dell Inspiron 531s Desktop Computer
R225M earpiece problem
If you bought a clone or non original earphone it can do that on your phone. Some of the PDA models are also very critical to the circuit wiring for the earphone, the switch, and the impedance.
If you are using the original earphone, and have this problem, it may be that there is a defect in the wiring, or the phone has a defect in its circuitry that works with the earphone.
Jerry G.
Jun 02, 2008 | Samsung SGH-R225m Phone
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
420 people viewed this question
 Grubhead
Grubhead
