Question about Gateway Wireless-B Router (wbr-100)
An adapter that broke or not?
I'm still confused, the adaptor is 120 V and i adjusted it into 220 V and it smoked a little. did it broke or can i use it again? does all store sell just the adapter?
  • 40 Answers
The adaper was too powerful, you should have stuck to the original voltage and you may have burned up some wires inside which was the reason for it smoking and you cannot use it again or the next time it may result to a fire and you dont want that so go to office max, staples, radio shack, or best buy to find the adapter that will work for you. I prefer best buy because there is always someone there in the computer parts to help and assist you with the product you are looking for. I hope that this will help you in some way, let me know and Good Luck!
Posted on Jan 24, 2009
  • 137 Answers
If you connect a 120v to 220v then its burnt out.. that was the smoke
Posted on Jan 20, 2009
Lost Power 120VAC cable, Am Now in Peru with 220VAC
1. Read the voltage info. on the razor. Their should be a label on the razor or info. in the instruction manual that came with the razor. 2. If the label doesn't say 120/220 input voltage you will not be able to use your razor. 3. If you use a adapter but the razor is rated for only 120volts input & you plug it into a 220volt socket you may burn your razor up & it may even cause death. 4. Remember find out the input voltage on the razor label & make sure it's the same as the output voltage as your wall socket. If it doesn't match, don't plug it up!
Jan 08, 2013 | Health & Beauty
I have an unusual problem with my GE dryer. I just moved in and noticed it was taking a longer time to dry my clothes than it normally did in my previous home. I checked to make sure it was getting 220...
here is the way it is wired on the back of the dryer:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
outlet should correspond the same, Hope it helped Tim
Apr 20, 2011 | Bosch Nexxt WTMC3321US Electric Dryer
No power, ac adapter was plug to 220v... pls help me
Did you mean that the ac adapter was a 120 volt and was plugged to 220 volts. ? If so the adaptor has failed int he power supply and must be checked. Please clarify.
Jan 24, 2011 | Microsoft Xbox 360 Console
My adapter is not working
US house current is 110-120 Volts and 60 cycles. Adapter must have this type of power. India has 220 Volts and 50 cycles ( Hz). You need an adapter designed for Europe/ India
http://users.telenet.be/worldstandards/electricity.htm
Feb 28, 2010 | Panasonic Lands Phones
What will happen if it is plugged into a 220 volt AC
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Oct 28, 2008 | Nintendo Wii Console
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
Work in Europe?
According to the rear panel of my 2200, it will accept 120VAC 50 ~ 60 HZ. Which means that outside of a proper plug adaptor, it should work fine. You need to adapt the epson power cable to whatever the French use. Be sure it is 110~120 VAC. Ran into some 220 in Italy
May 26, 2008 | Epson Stylus 2200 InkJet Photo Printer
AC Adaptor
If there isn't a switch to select 110 or 220 it should be ok , i had a charger like this and it worked well on 220 altrought I had to plug it with crocodiles clips
Oct 13, 2007 | Uniden BC92XLT Handheld Scanner
Gateway Wireless-B Router (wbr-100) Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
