Question about HP Compaq Proliant DL350 (345101-001) Server
Compaq proliant dl350 processor
Does the Compaq Proliant DL350 have a single core or dual core processor?
  • 63 Answers
As standard it has 1x Xeon single core 3.2GHz with a 2nd free CPU Socket
Posted on Jan 20, 2009
I have a Proliant HP DL580 G4 that had its system board replaced. The OS (Windows 2003 Enterprise) now only recognizes one cpu core. The server has 4 dual core cpu's. How can I get the OS to see all 8...
You may need to check your BIOS to make sure the multiple CPU function is enabled. Once it is, a reboot should correct this for you.
Good Luck
Sep 08, 2011 | HP Compaq ProLiant DL580 G4 (430811001)...
Hi, we are using HP DL360 with Red Hat 4.0, after installing sometime it created heavy noise during working after 2-3 days and the connectivity goes down, we need to restart the server each time to...
Big noise? Power Supply?
Even t log wouldn't always pick up a hardware failure that kills the machine. Goto HP Download diagnostic spoftware and see if that gives an answer.
Either that or when it does it, pull the lid off, listen to see where the noise is coming from (I.E. Power Supply, drives.. etc) and replace as neccesary.
Sep 04, 2010 | HP Compaq Proliant DL350 (345101-001)...
My server stalls in the middle of boot up.
The solution depends on exactly where it stalls. IF it stalls while booting the OS, either the OS files are corrupted so better try the recovery console or using the recovery CD.
Verify in the boot bios screen whether all the hardware are detected properly
Feb 12, 2010 | HP Compaq Proliant DL350 (345101-001)...
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
I can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
May 14, 2008 | HP Compaq ProLiant DL380 G4 Server
Scassy Card for Compaq Proliant ML 330 is defective
You cannot find the details of OEM of this card unless it is written on the card itself.
If you want to use a different make card. You can safely go with a adaptec make card.
Cheers - Parveen
Feb 05, 2008 | Computers & Internet
I have allredy missing scassy card for Compaq Proliant ML330
what can i setup my server
Feb 05, 2008 | HP Compaq ProLiant ML330e Server
How do I enable 64 bit processing on a HP Compaq Proliant DL580 G4
I don't think that you "enable" 64 bit processing, you buy a server with a 64 bit processor. Intel's Itanium is such one. You then install Windows Server 2003 x64 version.
That's pretty much it I think.
Jan 15, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
HP Compaq Proliant DL350 (345101-001) Server Logo
97 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
