Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
Aunthentification field when i connect to wifi of my samsung sorby 2
Steps to activate or to connect wif using this samsung gt-b5310
Thanks, bigbadbry69. My samilar issue was resolved by following the suggestion!
Just remind here the "WEP password" is from router and put into mobile's "Network Key" field (WIFIi->search/select connection -> scroll down to Network Key).
Sep 11, 2012 | Samsung GT-B5310 Corby Pro GSM Slider...
I have bought a n150 but it doesnt appear to have wifi capabilityies, it connects with lan but shows no wifi networks. in device manager it shows 2 x bluetooth adaptors, one pci-e fast ethernet apaptor...
Your laptop has wifi capability. The problem is that you don't have the drivers installed for the wireless card and for your video card. Fortunately, this should be an easy fix.
Because you haven't give me the model code or what operating system you're using, I'm going to give you more general information.
1. Follow this link to Samsung's support page. http://www.samsung.com/us/support/#
2. Click "Laptops" under "Office".
3. Click the appropriate information in fields 1,2, and 3 and then click Select.
4. Click "Get Downloads".
5. Select the "Driver" tab.
6. Depending on your operating system, scroll down and find the
VGA Graphics driver and click on it. It will give you instructions on how to install the driver. Now click on the ZIP symbol under the File field on the far right. Follow instructions to install video driver.
7. Do the same as step 6 except find the Wireless LAN driver. It appears there are two drivers listed on the Samsung website. Try one, if it doesn't work, then try the other driver.
8. Restart computer after installing drivers.
Good luck, thanks for using FixYa, and please post back to this solution if you have any difficulties.
Apr 12, 2011 | Samsung N150 (36725723009) Netbook
I am unable to connect my Samsung monte s5620 with my bsnl teracom wifi modem. Although, I can connect it to my pc.
1.Verify the network key you have entered in the WIFI settings.
2. Check the Encryption type is TKIP.
3. Uncheck static IP in advanced settings.
4.Protocol must be set to HTTP in WIFI settings.
Nov 16, 2010 | Samsung S5620 Cell Phone
How to connect samsung star GT-S5233W to internet and how to download games, to send mms to another phone? please answer me..
there is two way to connect internet1. is wifi and 2. is network provider. follow these steps if you have wifi connection
1. goto wifi and turn on the wifi
2. then press search buttun
3. then you will see the wifi connection
4. press to select the "connect" opntion
5. then save the configuiretion
note:- if the connection has password enabled then
goto "network key" option in network
configuiretion and write the password
and save it.
6. close all and reboot the your phone again
and repeat the step 1.2.3. and 4.
and for the network provider:-
1. ask for the internet configuiretion
to company you have the network
and they will send you the configuretion.
by sms.
2. install the configuiretion and your are
done.
Aug 13, 2010 | Samsung Star GT-S5233 Cell Phone
Setting up email feature on samsung gt5233w :)
how to get connect to wifi through samsung gt5233w
May 08, 2010 | Samsung Star GT-S5233 Cell Phone
Wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
May 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How can i connect my samsung corby pro phone to wifi?
1. go to "menu"
2. go to "wi-fi"
3. click the central icon (it will activate wifi)
4. click to "search" (it will search available wifi links)
5. click on the desired wifi-link
6. click "connect"
Apr 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Detecting wireless network but will not connect.
1.check our IP
2.check the field strength meter of wifi that our receive, 2 or 3 bar sometimes only detect butcannot connect
basicaly nedd tansmit and receive for connect
MAYBE, just maybe, our wifi transmiter doest work (perhaps because its not set to full strength-maybe) or just broken.
Sep 29, 2009 | Toshiba Satellite A105 Notebook
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
