Question about Honeywell Programmable Thermostat Heater
With new digital thermostat furnace runs every 10 min.
Digital thermostat drops .5 degrees and furnace will start. I set a digital therm and humidity gage next to thermostat to compare. Can I change the setting on the digital themostat so there would be a bigger window before it runs. If I set it at 68 degrees it will never go off that number whether its running or not. It ran 2 times while I am working on this email. Its a honey well thermostat
  • nnaschmitt Feb 03, 2009
    Thank you
    Checking with people who have digital themostates and our furnace guy this is how ithey are.
    Thank you,Dave S
  • 68 Answers
You did not say what model you use. Depending on the model , there might be setting for 'deadband' or 'system type'. Changing that value will affect when it turns on. If it switches on that frequently and the room feels comfortable, it might be that your thermostat is placed on wrong place - one which cools of quickly, or there is draft cooling it off. Digital thermostats have a 'learning period' and adjust to dynamic of the room.
Posted on Jan 20, 2009
    Novelist:
  • 88 Answers
Which type of T-Stat is it ? most standard t-stats have it built in that the temperature range is only a half a degree, it may seem like its running alot more, but in actuality it is maintaining better home comfort as it is not running as long as the old bimetal t-stats which would have a range of anywhere from 2-5 degrees which would cause the furnace to run alot longer, use more energy, use more fuel, and you would notice a definate change in the house temperture before it would come on or shut off, your t-stat seems to be working properly, and it will save you money, remeber also to change those filters !!!
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
Duo Therm Heat Pump Does not Run, Shows Aux Heat Mode, Switches to Furnace Heat
The control that monitors the cutoff temperature may need to be adjusted. Your hetpump may also work effectively at 16 degrees. you have not left any information on the make or model of the heatpump or the thermostat.
Aug 16, 2014 | Heating & Cooling
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
Lennox merit series furnace is not kicking on until house is 8 to 10 degrees colder then set thermostat
I have the same issue with a G21Q4-5-100-1 model lennox. House drops 8 - 10 degrees. I have 3 thermostats and all react the same way. I was told by service tech that the Ignition Coontrol Module is bad and acting intermittanely. ???
Jan 31, 2010 | Dayton Gas Furnace Heater
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
New thermostat honeywell RTH7400 cycles oil furnace every 10 min.
rth7400 maintains a 1 degree differential in temp so 10 minute cycles are not unusual.
Vinnie
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Dur-therm furnace heat controll with Dometic remote
i would suggest that you look at your thermostat,it may be to close to the furnace keeping in mind that all thermostats have a certain tempreture drop (or gain) before restarting john
Dec 28, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
224 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
