Question about Sony PS-LX250H Turntable
Turntable belt wont stay on - Sony PS-LX250H Turntable
  • Sony Master
  • 5,190 Answers
You have tried replacing the belt?
Posted on Jan 16, 2013
Turntable not rotating. What should I do?
HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
Jun 20, 2014 | JVC AL A158BK Turntable
Wont spin
Hello Bella, This is a belt driven turntable. Most likely, your drive belt has fallen off. It may be too stretched to stay on. To check this, remove the rubber platter mat. There should be holes in the metal platter, which if you rotate it, you will see the belt and the motor pulley. Remove the metal platter by grasping the holes. It should lift off. When the platter is off, try to slip the belt over the inside flat part of the platter. It should be snug. If it just falls off, the belt needs to be replace. For more information or parts, please go to my website, AUDIOSERVICECLINIC.COM. You can contact me through the website, and we can take this issue further if need be.
Thank you, Dave
Audio Service Clinic
Apr 13, 2014 | Aiwa PX-E860 Turntable
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Need to replace the belt on my JVC AL-A95 turntable
To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
Oct 08, 2011 | JVC AL A158BK Turntable
Has power but wont spin
Hi,Dead as in no power up or dead as in the turntable will not spin?? If the turntable isn't spinning check and see if you have a direct drive or belt driven.Getting back to your turntable, if it is belt driven your belt may have become dried rotted. replacements are available at
elexatelier.com/ ,
elexatelier.com/ or
needledoctor.com ... good luck, definitely worth getting it up and running again...
Have a nice day..
Feb 17, 2011 | Numark TT200 Turntable
I have a america dj turntable and the record plate wont turn. What could be the problem?
try the belt in the belt drive, may require pulling it apart but if you can manage it belts can be easily found on ebay. hope this helps
Nov 02, 2010 | American DJ TTD-2500 MKII Turntable
Light and fan stay on and turntable no longer work
Not sure if your model has a belt driven turntable or gear driven. The cause of your problem is most likely a worn or loose drive gear or a drive belt which is worn or has come off.
Best have this checked at your local repair shop.
Best wishes,
Graemevm
Jan 24, 2010 | GE Profile Spacemaker Over-the-Range...
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Sony PS-LX250H Turntable Logo
111 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
