Question about Dell Dimension C521 PC Desktop
Why can't I get Flash to work on Facebook apps on Dell Dimension 3000 Desktop
  • Dell Master
  • 2,386 Answers
Install new version of flash from adobe web site
Posted on Jan 08, 2013
  • 42 Answers
SOURCE: Dell Dimension 3000 keyboard error
Hi Sir Another fix you could try is looking in your device manager and checking what keyboard device is registered if it says that you are using a ps2 then you need to uninstall the device and then close the device manger after which you should unplug your key board and restart your computer when you hear the bleep reconnect the keyboard into your USB port and see if this works if not you need to check if you have enough power to your keyboard from your USB port as some USB keyboards need power is your USB port 2.0 if not try to upgrade your USB to 2.0 from the usual 1.1 ports Hope this helps Paddy
Posted on Sep 08, 2007
freetek
  • 5568 Answers
SOURCE: how to reboot dell dimension 3000 desktop
If you have disks supplied with the system, they normally offer more than one type of reinstallation; destructive and non-destructive.  In most cases, neither of these will absolutely remove all traces of former files. If that is what you wish, you can reformat the hard drive and remove the existing directory and make old files unaccessible except to experts wanting to 'get the goods' on someone.
There is also the chance to backdate the system to an earlier time in case something has bollixed enough files to make it unstable. That procedure is called 'restoration' which replaces the system files as they were at an earlier time so corrupt files are replaced with fresh copies from a separate partition on the drive. This method leaves your personally created files intact if that is desired.
These various possiblities depend somewhat on the version of Windows you are using and information in the Windows Help section can give you guidance if you want it.
If you have sensitive information that you do not want anyone to ever access, there are numerous freeware programs that will overwrite existing files so completely that even experts cannot recover them. They use various methods of trashing files but most offer the chance to set how many times you want them overwritten and by which method, among these is using all zeros or random numbers.       Finally, the last option is to replace the hard drive with a new one, physically disassemble and destroy the disks mechanically although disposal would still be sensitive since there are methods of reading file segments on even catastrophically damaged disks.
Posted on Dec 25, 2008
gotgeek2
  • 565 Answers
SOURCE: forgot my password to my dell dimension 3000, how can I reset?
It's a large file, but you can download and burn a copy of:
http://www.ubcd4win.com/
It's a bootable cd that has a password recovery tool plus a lot of other stuff.
Posted on Feb 13, 2009
APremkumar
  • 564 Answers
SOURCE: dell dimension 3000 desktop won't play sound
Download the Drivers for the audio.
go to Support.dell.com website and  enter your service tag and download the right drivers for your computer.
Thanks, PREM
Posted on Mar 30, 2009
  • 15 Answers
SOURCE: wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Posted on Apr 14, 2009
Which power supply connectors plug into which drives in a dell dimension 3000
P1 is about the same as the rest but for a slave drive p7 should be ok
Jun 21, 2013 | Dell Dimension 3000 PC Desktop
Replaced video card in Dell Dimension 3000 with NVIDIA GeForce FX 5500. Can't find video controller driver
Hi.
Click on the link below and download the driver for the card, if you are unsure then click on the Supported Products tab and you will see that the FX 5500 card is supported in the download.
http://www.nvidia.com/object/winxp_175.19_whql.html
Regards.
Feb 04, 2013 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 won't turn on
No way to teat but to install another PS.
Jul 31, 2012 | Dell Dimension 3000 PC Desktop
Hello Mr. Expert I have a Dell Dimension 3000 desktop. I upgraded to bios to A03. Is it possible to upgrade to a higher version. Thanks,
Hi!
The A03 is for now the latest version for the BIOS of Dell Dimension 3000
And a tip for you: upgrading bios is only necessary when real issues occure and the computer doesn't work properly.
Please let me know if it helped
Best regards!
Aug 09, 2011 | Dell Dimension 3000 PC Desktop
No video and Crashed audio on a dimension 3000
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=en&catid=&impid
Rob
Mar 04, 2011 | Dell Dimension 3000 PC Desktop
How much ram memory can i put into a dell dimension 3000?
On a Dell Dimension 3000, there are 2 memory slots.
The maximum RAM memory capacity is 2 GB or 2048 MB.
For prices and availability of parts and upgrades for this system, call 1-800-357-3355, which is the sales dept of Dell.
(I am presuming that you are in the USA).
Also click on the foll. link :-
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6436&cs=19&l=en&s=dhs&mfgpid=166945&chassisid=8226
Sep 22, 2010 | Dell Dimension 3000 PC Desktop
No volume on my dimension 3000 desktop
Try to reinstall the sound card driver. You can download it from the following link: http://supportapj.dell.com/support/downloads/driverslist.aspx?c=hk&cs=hkdhs1&l=en&s=dhs&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=ck&catid=&impid=.
Feb 11, 2010 | Dell Dimension 3000 PC Desktop
Reformated C: drive and cannot reload Dell drivers for display & audio
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} After installing Windows, use the CD that is provided with your Dell PC. The CD may not be bootable, but it will contain all the driver's and other applications on it for you to install. you need to first have your pc working with the windows OS. Then load the CD and follow the menus to install each driver, for each device in for your particular model Dell PC.
If you don't have the CD, then you can go to the Dell website where you can download each driver and other apps for your PC to get it to working condition.
Jul 05, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension C521 PC Desktop Logo
49 people viewed this question
Alun Cox
