Question about HP Pavilion dv6000z Notebook
How can i turn my desk top off when the power is still on but the screen is blank?
Its new and i haven't got it sorted yet!
  • HP Master
  • 32,281 Answers
Press hold down the power button until it turns off.
Posted on Jan 07, 2013
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
How to fix a blank screen on a compaq sr5000 desk top?
Try rebooting to see if that clears up the issue. Should. Does not mean it will not happen again if you repeat the operation that caused the BSOD. There is an issue with your OS and you might want to attempt a repair operation if possible
Sep 03, 2017 | Compaq Computers & Internet
The screen is blank and will not play
These have a small lithium rechargeable battery inside and prolonged charging (like overnight) tends to cause them to stop charging. You may even notice the battery is swollen if you remove the cover.
I've replaced the battery in a few of these using a battery of the same size & voltage/amps that I found on eBay. There are other sources but I've found that if you type in the numbers on your battery you'll find a match there. It is a bit of a wait, but usually they're not as expensive and offer low cost or free shipping.
There's probably a local supplier of these, I just haven't explored that route, you may try the WWW approach.
By the way, all of your music/videos files & such should be fine.
I actually use some of the defective broken MP3 & MP4 players as thumb drives holding Windows programs on them to transfer into new PC's. Currently they are as you described yours, but the data is still there.
Mar 22, 2012 | RCA Audio Players & Recorders
Mouse is frozen, i want to reset my notebook and dont know how
Make sure you haven't disabled the Track pad. Check to see if there is any buttons around the Track pad or around the 'F' keys.
If its not that the computer will have more than likely frozen. Just press and hold the Power Button until the screen goes blank. Then turn back on
Sep 04, 2011 | Computers & Internet
Blank screen on my dv9608ca laptop i changed power inverter and screen its very dark can faintly see desk top items. everything works when in connect to different monitor so can it still be video card
It sounds like your laptop's Back Light is out. The screen has two layers, the LCD display, which provides the image, and the back light, which gives it brightness and clarity. Unfortunately, it is no easy fix and typically costs more than a new laptop to replace. I'd recommend calling HP themselves if you want to get it repaired.
Aug 26, 2011 | HP Pavilion dv9608ca PC Notebook
How to set up my desktop in a clean way?
The Desktop Cleanup Wizard is a component included with Microsoft's Windows XP operating system. It aims to reduce the clutter in a user's desktop environment by moving unused shortcuts to a separate directory called "Unused Desktop Shortcuts"
If you are not using XP .
1.Right click on desk top.
2.Go to sort by and choose an option
3.Right click on desk top
4.Choose New
5.Select Folder.This will create a folder on your desk top which you can drag and drop all desk top icons that you do not need regularly.
6.Create another folder and use it for down loads.This will keep it clean.
May 11, 2011 | Microsoft Computers & Internet
Blank Screen
Well it is possible to install a new screen relatively easily... It is a bit of a mission, Ya need to get a replacement screen & driver board and do the reverse procedure from removal. A screen can be got from say, Ebay, or the net. Otherwise get a reputable place to do it for you.
Jan 26, 2010 | Acer Aspire 3610 Notebook
Mouse V450 shipped with new Dell Desk top does not work reliably
It should be good up to 30 feet, whatever the setup. You might try plugging the send/receiver into a front port to see if that helps.
I usually open Device Manager, open each USB device and set the power to stay on, (not "turn off this device to save power"). That way, sleep mode won't cause you to lose contact with the mouse. Or just disable sleep mode.
May 18, 2017 | Logitech V450 Laser Cordless Notebook...
HP Pavilion dv6000z Notebook Logo
19 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
