Users manual and tv codes for echostar 153637
3 Suggested Answers
SOURCE: I need the code for an echostar remote ir103602
How to Program a EchoStar Remote Control
Instructions
Step1
Ensure that the remote control has new batteries installed. If you are not sure or have been using the device for a while, go ahead and insert fresh batteries. You need four AAA batteries.
Step2
Locate the mode buttons on the controller. You will see SAT, AUX, TV, and VCR. SAT stands for the satellite receiver. Your remote is automatically set up to work with your EchoStar receiver, and you do not need to program it for this function. AUX may refer to a cable television device or an audio device that hooks it into your stereo system. TV refers to your television set. VCR may be chosen to control a standard VCR or a DVD player.
Step3
Press the mode button that corresponds with the device which you want to control with the EchoStar remote control. For example, if you want to program the remote to control the TV, press down the TV mode button.
Step4
Turn on the device. This is the item you want to control with the EchoStar remote. You may need to do so manually or with its own remote control. In this example, you would turn on your television set with its own control.
Step5
Press down the EchoStar mode button for the device again, but this time hold it down for three seconds. You are going to notice that all the other mode buttons are going to flash on. Aim the remote at the device you want to control.
Step6
Depress the EchoStar remote power button briefly and then slowly click either the up or the down arrow button. You are performing a code scan that allows the remote control to run through all the preprogrammed codes that are stored in its memory. Proceed slowly and do not hurry this process. It may take a few minutes, but it is virtually foolproof.
Step7
Stop when the appliance you want to control with the EchoStar remote control suddenly turns off. You have hit upon the correct code, and if you save it now, your remote will be able to use it in the future to control the functions of the item.
Step8
Store the code in the EchoStar remote control’s memory by pressing the pound button. You will notice that the corresponding mode button is going to flash, acknowledging the programming choice. You are now ready to control the item with the EchoStar remote control.
Posted on Jan 09, 2009
  • 11800 Answers
SOURCE: I have a Aiwa AV-DV70U AV-Stereo that I want to
In that case you have only one option left: perform a code scan on the remote - it will try all of the stored ones. If even now you can't find a good one the Echostar remote doesn't have the code for your Aiwa so you can't use it. Sorry you can't fix that, the remote is incompatible to your device.
Posted on Oct 15, 2010
My remote does not turn on the tv and control the volume. Can you give me some codes to try for a vizio tv?
From the user manual,for 5 digit remotes (like most Direct TV units) use codes 11758 and 10178, then 01377, listed in order of preference. For 4 digit remotes use 1758, then 0178. For 3 digit remotes (Echostar or Dish Network) use code 627
Oct 01, 2009 | Vizio VW42LF 42 in. LCD HDTV
Echostar 311 box codes ?
You can go to Dishnetwork.com and go to the tech portal. There you can select your receiver type and opt for a manual which will display in PDF format. This will allow you to enter peripheral codes as well if you need them as welll. Thanks for using Fix Ya.
Sep 10, 2009 | DISH Network 311 DTV Receiver
I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
May 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Jai un remote 1.5 echostar 429.718 et je veut men
Oui. Dans ton manuel ExpressV, ils expliquent en page 3-10 et les codes sont en pages suivantes.
SI tu n'as pas le manuel, voici:
Le code de Sharp sera un de ceux-ci: 628, 605, 608, 740, 526, 585, 591, 606, 607, 629
Appuyer sur le bouton TV du remote jusqu'à ce que les quatre boutons blancs allument;
Entrer le code de sharp (par exemple, 628) suivi du #. Le bouton TV clignote 3 fois.
peser sur le bouton rouge (power). La TV derait se fermer. Si ça ne fonctionne pas, réessayer avec le code suivant, 605, et ainsi de suite.
Mar 17, 2009 | Sharp Televison & Video
I have a disney princess T.V. and I lost the remote for it, I bought a univercial remote and cannot find the code to use it. I followed the directions and the code is not listed in the paper that came with...
My disney princess tv model P1310ATV uses code 759 with Echostar 6.2 and 6.3 remotes. This code is listed in the echostar manuals as a code for Hisense manufactured TV's.
Feb 28, 2009 | Disney 13" TV
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Echostar 5.0 remote
https://rweb.echostar.com/departmental_content/TechPortal/content/tech/remotes/5.0.shtml
Dec 26, 2008 | Universal Remote Control Activity Based...
CANT GET TOSHIBA CT 90302 TO PROGRAM
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Sep 01, 2008 | Kenwood RC-R0720 Remote Control
Instructions
Step1
Step2
Step3
Step4
Step5
Step6
Step7
Step8
Aug 28, 2008 | Televison & Video
Televison & Video Logo
264 people viewed this question
Top Televison & Video Experts
