Question about Reebok 8700 ES Treadmill - Silver Service Delivery! at GNC
I believe that my Reebok 8700es was plugged in during a power surge. I bought a dedicated extension cord and plugged it back into the wall and turned it on. Nothing happened. There were no sounds a
I tried turning on and off the original power strip (while plugged in) but that didn't work either. The words "Premium Lifetime Frame & Motor Warranty" are listed in a blue strip right above the rubber part of the treadmill. Can anyone help?
    Top Expert:
  • Reebok Master
  • 12,223 Answers
Step 1:
1) Please NEVER use extension cord, this will bring dangerous spikes, glitches, that will affect to your treadmills.
Disconnect it and use the specific outlet wall, for your machine
2) I recommend that you use the Software calibration for easy diagnose, troubleshooting and fix it. This will be clear the information code appearing the display.
Go ahead
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 3:
I believe that my Reebok 8700es was plugged in dur - 1_7_2013_4_55_27_pm.gif
Posted on Jan 07, 2013
2 Suggested Answers
SOURCE: hi my reebok treadmill was plugged in during a
how do i replace the drive belt on8700es
Posted on Aug 07, 2010
How to turn on hp 3600
Unplug the power cord from any surge protector, extension cable, or power strip, press the power button on the printer several times. Plug the power cord directly into a wall outlet.
Feb 21, 2015 | HP DeskJet 3650 InkJet Printer
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
The treadmill stops after about 20 minutes or so. I push the fuse back in, and then I can start it again. It shuts off again after 15 - 20 minutes or less. Can I replace the fuse, or what is the...
try lubricating the running belt. Any decent sized fitness store should have a lubrication kit. Also, make sure the machine is plugged into a dedicated circuit. Meaning, there are no other devices on the same circuit as the treadmill. Not just the same outlet, but the entire circuit of the room you have the treadmill in. You also want to make sure it's not on any extension cords. Plug it into a surge protector (power bar with a cord less than 6') and then directly into the wall. Those are the 3 main culprits why treadmills shut down after a short period of time.
Jul 10, 2010 | Proform LX660 Treadmill Walking Belt
My display screen is rolling and nothing stops it. My computer says the printer is offline.
Try doing this procedure to correct the problem.
1. Unplug the power cord from the back of the product.
2. Unplug the power cord from any surge protectors or power strips.
3. Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4. Plug the power cord into the back of the product.
5. Plug the power cord into the wall outlet.
6. Press the Power button to turn the product on.
7.Now check if its already working.
May 16, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I have a gateway desktop computer. Recently moved
Before you actually replace the power supply, check some other things first:
1. Wall socket
2. Power strip/surge protector
3. Power cable
4. On the back of the computer, where the power cable plugs into, is the red switch set to 115? It should be 115.
5. Make sure that the power cable is not connected to a regular extension cord. Power cable must plug directly into a surge protector that is not daisy-chained to another power strip, surge protector, or normal (household) extension cord. Surge protector must be directly plugged into wall socket.
If none of the above solve the problem, open up the case and ensure that all power connections are secure. Also check ALL other components' connections. Any loose connections can cause problems for you.
If everything is secure and the problem persists, replace the power supply.
Nov 27, 2009 | Office Equipment & Supplies
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Having a problem with a heater i bought
I have the same heater and when that happens just unplug it for about 15 minutes and plug it back in and it should work fine. It only does this for me when I am using a extension cord or a power strip. It needs a dedicated power supply (wall outlet) with nothing else attached. If you must use a extension cord I have found that the heavy gauge orange power cord is the only one that does not overheat and causes the heater to shut off. The heater comes with a 3 year warranty, the longest warranty I have ever seen with a heater.
Mar 25, 2008 | R.A.M. Computers LASCO-5540 Ceramic...
Honeywell 18155 Air Purifier
did you ever solve this issue? I just borrowed my mom's and it worked fine for two days and then suddenly won't turn on at all. I wonder if there is a fuse that might have blown during a power surge while we were out of town or something...
Any help would be appreciated.
Oct 27, 2007 | Honeywell (18155) Air Purifier
Reebok 8700 ES Treadmill - Silver Service Delivery! at GNC Logo
98 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
