Question about Lakewood 750 Oil Filled Baseboard Heater
Lakewood 750 doesn't heat
Friend I received heater from suggested switch. he could get heater to work sometimes by doing something with exterior switch. opened up heater to see if inside sitch was a problem or if there was some type of a balance shut off that needed something. couldn't observe a problem. it does sound like there is not a lot of oil in this unit but I don't see leaks.
  • 34 Answers
Visit http://www.lakewoodeng.com/html/parts.html for service center and parts.
Posted on Apr 18, 2009
Lakewood radiator heater model number 5101. The heater just stopped working all of a sudden. The buttons still light up when switched on but there is no heating. please help as I dont have any other...
Sounds as if the element is burnt out or the tstat is broken. the tstat is the more common as they use very cheap ones. Unfortunately you can't get these. My suggestion is to buy a new one.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
I have the 750 and the caution light always stays on and unit is no longer producing heat.....
This is a limit switch problem. You need to replace the limit switch. It may even be a resetable one. If it is, then you can just simply push the bottom on the back of it and it will reset. If its not then you will have to replace the Tstat.
Jan 25, 2011 | Lakewood 750 Oil Filled Baseboard Heater
I have a Lakewood Model 750 Strip Heater and the caution light is lit. How do I get the unit working again.
chances are the thermostat has been damaged due to excessive heat or corrosion has accumulated on the connections coming from the temperature dial. it is possible to bypass this component but not advisable, if you choose to do so, please monitor the heater at all times and be sure to unplug it while not in use. replacement parts are still available.
do not attempt to service the heater while it is plugged in to an electrical outlet.
Nov 05, 2010 | Lakewood 750 Oil Filled Baseboard Heater
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Lakewood 7096 heater
Some of the newer models have a thermal fuse which may be blown. It doesn't look like a normal fuse at all. It is similar to a transistor in looks and should have continuity from one end to the other. It will be tied in to the incoming power cord inside the heater, and may be covered with rubber coating within the wire. It will look different when you notice it. Sometimes its too far down inside where the heat causes it to blow prematurely. The purpose is to cut the power to the unit in case it overheats. You can get one at radio shack for less than a couple of bucks. The older models don't normally have one, but I would suggest you put one in it if that's the case.
Dec 16, 2007 | Lakewood Oil-Filled Electric Radiator...
Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Apr 14, 2007 | Lakewood 792/JR Utility Heater
Lakewood 750 Oil Filled Baseboard Heater Logo
266 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
