Question about Air Tools & Compressors
Can't remove trigger valve from my Dewalt D51844-- even with lots of force, pulling with pliers
Gun won't fire after a few months in storage. I'm getting the puff of air at the trigger, so trying to replace trigger valve. I removed the trigger, but cannot figure out how to remove the trigger valve, which I read is supposed to slide out. Using needle nose pliers to try to pull it out, but not getting anywhere. Suggestions?
    Problem Solver:
  • 3 Answers
Have you tried a good soaking with a thin type oil like WD-40 yet?
Posted on Jan 08, 2013
5 Suggested Answers
  • 1383 Answers
SOURCE: NV65ah Hitachi nail gun "how do you remove the trigger piston"??
If you do not have a breakdown of the gun go here www.toolpartsdirect.com and select brand, then select coil nailer, finally look for your model number. With breakdown, find parts labeled 51 thru 54. The trigger pin (#53) and the retaining ring (#21) hold the trigger. Remove these then remove the trigger. Find several #51 roll pins on the gun and punch out the uppermost pin where the trigger valve is located (3mm size). The uppermost rollpin holds the trigger valve in-place. After you have removed the rollpin/s connect air supply to pop-out the trigger valve. Caution, use a heavy glove (or reduce pressure) to catch valve as it can come out with force. When incerting the rebuilt valve, use caution not to cut new orings as the valve is pushed in. Good luck and email if you have more questions.
Posted on Mar 15, 2009
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
airnailer
  • 109 Answers
SOURCE: dewalt angled finish nailer, just got, when nose
if air is released when the trigger is pulled then stops when the trigger is released , then the trigger is doing its job. its probably a firing valve issue. four screws will take off the top cap of the gun the firing valve is inside of the cap . first check to see if the gun has enough oil( unless its an oil less gun) if its dry then grease or oil all of the orings, if this dose not work check to see if any of the orings or plastic parts need replacing. pls rate this answer...;tks
Posted on Feb 16, 2010
  • 1383 Answers
SOURCE: Dewalt D51822 nail gun does not fire nail. When
There are 4 orings that cause this problem. Two are in the trigger valve installed on the firing pin. The firing pin can be seen just under the trigger, however if you replaced the valve, you could assume no problems with the trigger valve. I would take apart the old trigger valve and examine the orings on the pin. The pin should fit snugly in the trigger valve cap and also in the valve. If the orings look good and it does fit snugly, most likely valve is still good. The other two orings to suspect are installed on the cylinder inside the nailer and make contact with the bulkhead (white plastic piece that seals the cylinder note parts reference 55, 74, 11 on the parts list). For parts list and to order parts go to www.toolpartsdirect.com Good luck with your repair.
Posted on May 27, 2011
Dewalt D51238 not firing when trigger pulled but air does come out?
Remove the head and lube the headvalve with white grease. If gun still does not fire and makes air noise at the trigger valve then orings within the trigger valve are worn. Replace the trigger valve or if you have a source for small orings, just replace the two orings on the metal stem (2mm x 1.5mm). Dewalt uses vinyl orings on the stem that fail. Replace with buna. Good luck
Oct 13, 2014 | Air Tools & Compressors
I did a complete rebuilt kit and replaced the o rings and trigger vavle. There is no more air leaks but the gun isn't firing at all. What should I do now?
Remove the nails and remove the trigger to expose the firing pin on the trigger valve. Connect air and very quickly depress the firing pin all the way in with finger. If the gun fires, adjust the safety foot to depress the firing pin all the way in. If the gun does not fire, most likely the problem is that two orings that make contact with the cylinder spacer (white plastic piece around the cyl.) and the cylinder are leaking between the chambers. Check for snug fit as spacer could be worn. Pull out the cylinger and remove all the lower parts so that you can slide the cylinder in and out of the spacer. The cylinder should fit snuggly into spacer and have some resistance. Try with one oring installed on cylinder , then both as one or both may not be snug enough. If it fits loose, install a couple of winds of Teflon tape into oring groove then reinstall the oring. Again check for snug fit (or replace the spacer if surface is scratched). Reinstall using white grease and retest. Good luck.
Sep 13, 2013 | Dewalt D51844 Framing Nailer
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Dewalt D51844. Framing out a wall today and the gun worked fine on the first wall. I was starting the second wall and heard an air leak coming from the gun. Would not stop. Tried several things and...
Most all of my guns are senco and the head has the moving part for fire and reload,, controlling the driver piston. Multiple shots suggests a trigger problem. No water in system right.. Well Its all O rings little ones,, skinny ones,, fat ones etc. You can open it up and check, do the head first, I think.. Its fast a off and on
Jul 15, 2012 | Dewalt D51844 Framing Nailer
The gun constantly exhausts air when connected to air compressor. Won't build up the pressure when connected. Must disconnect between firing trigger
Easy fix if air is leaking out the top of gun. Remove the head and lube with white grease or silicone paste. If orings seem to be loose, order repair kit from dewalt (you can tighten orings by removing the oring and wind a bit of teflon tape in the oring groove). If air is leaking from the trigger, replace the valve. If air is leaking out the bottom where the nail ejects, pull out the cylinger and lube the orings that seal the cylinder to the body of the gun.
Oct 19, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Hey, I'm having trouble with my Dewalt 18ga Brad Nailer trigger. Can you send me the directions you have on how to get into this thing? I'd really appreciate it.
For removal of dewalt D51238k trigger valve. Remove the nails.
Remove the pin holding the trigger in place. Then remove two roll pins in the body of the gun just above the trigger (3mm roll pins). With gloved hand, apply air pressure to the gun which will pop out the trigger valve. Use caution because the valve could come out with force. Try with low pessure first, then increase as needed. If you are removing the trigger because the gun will not fire, (only puff of air from trigger area), suspect problem in the head valve instead (usually, trigger valve is bad if air leaks from trigger when you connect air ). Good luck
Sep 26, 2011 | DEWALT D512381 18Gauge Brad Nailer ORing...
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
Dewalt Nail Gun D51844. Same problem as other guy - air blowing out with trigger off. Taking it apart, not sure the cylinder comes off, seems to be held in by a hard plastic housing - called a Bulkhead. ...
Dewalt uses about 4 or 5 orings within the gun made of semi clear urethane that fail (turn gummy and breake apart). Two are under the bulkhead and at least two in the trigger valve. To remove the bulkhead pull up on the white housing. With housing and cylinder assembly out, push down on the black retainer at the very bottom and remove the oring(take a picture of the assembly after each stage so that you can re-assemble the spring and checkvalve correctly). You will find two large orings under the bulkhead against the cylinder that need to be replaced (also the orings in the trigger, or replace the trigger valve ).
Jan 01, 2011 | Dewalt D51844 Framing Nailer
D51844 Framing Nailer won't fire
Adjusting the depth of the nail also changes the amount of pressure that is applied to the trigger pin. This is not actually a problem with the adjustment, however indicates that the orings in the gun are not completely sealing or is lacking lubricant. Adjust depth so that maximum pressure is asserted against the trigger pin. The trigger pin must be pushed all the way in very quickly to fire the gun. Test by removing the trigger and depressing the trigger pin by hand all the way in quickly. Enjoy
Dec 05, 2008 | Dewalt D51844 Framing Nailer
Air Tools & Compressors Logo
95 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
