Question about Toshiba 46SL417U LCD TV
Does the power board on a tv control the buttons on tv and remote sensor
No i would suspect the the IR board or main board ..also check remote with a ir remote tester to make sure it works
Posted on Jan 07, 2013
  • kalan Jan 07, 2013
    and the switch board for the buttons
I have a e422vle Vizio TV. The power board went bad, I ordered a new one and the Tv now is working but the remote doesn't work. Is the remote sensor on the power board?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV.
http://electro-medical.blogspot.com/
Jan 05, 2017 | Vizio E422VLE 42 in. LCD HDTV
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=yokn68wxkhym@namo.co.kr&sep=%7c
    1. Press the POWER button on the remote control.
    2. [img src="http://support-us.samsung.com/cyber/namo/namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=79HKC8BOY9YC@namo.co.kr&sep=%7C" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Remote sensor board rca tv model p52928
Disconnect the board if you have a real working remote, set will work via the remote without that board---remote sensor is behind screen and above the board.
Nov 28, 2012 | RCA P52928 52" Rear Projection Television
3 yr old KDL-40V3000. Remote suddenly stopped working. Changed batteries twice - didn't make any differnence. Then noticed no LEDs lit on TV front pane! But TV is powered on. Also TV can be operated...
U have a Digital Camera turn it on,take ur tv remote pushes all the remote buttons on the front of the Digital Camera.One by one buttons.If all buttons of the tv remote work will register on the Camera viewing screen,because the Digital Camera able to read infer red signal output.Will figure out wright away the tv remote work or not easily.Tv remote sensor/board have no LED power light lite up might just be a lose connection or just a dead LED lamp only,because all the buttons on the remote sensor/board to the tv panel work wright?Try website Remotes.com to buy tv original remote.
Jun 10, 2011 | Sony BRAVIA KDL-40V3000 Television
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any...
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Jan 03, 2011 | RCA L32HD31 32 in. LCD HDTV
Where is the eye for the remote on the TV????
Hi, remote sensor is located behind the front screen, if the remote doesn`t work as well (you didn`t say so I`m assuming it doesn`t) then you either have bad tact switches on the control board (the buttons on the front of the set) or the 5 volt line to the control board is missing, video-tek
Feb 03, 2009 | RCA P52937 52" Rear Projection Television
Tv turns on and off
My JVC 35 " AV 35750 toggled on/off non-stop too.
Fix for me: Unplug TV. Trace cables from on/off switch to main circuit board. I unplugged the cable at that point to eliminate the the on/off button and remote control sensor. Applied power to the TV and my TV stopped cycling on/off so I figured the problem was probably not on the main circuit board but with the push button/ remote control sensor board. I again removed power from the TV and plugged the cable back in to the main circuit board. I then applied power back to my TV to verify my symptom, but when I did this, the TV worked fine again.
Many times resetting circuit board connectors will clear electrical problems.
Jul 22, 2008 | Televison & Video
Remote control Sensor for tv
The IR sensor on the main circuit board may have gotten zapped or possibly the window where the IR signal passes through may need cleaned. It's located on the front of the set near the control buttons. Stargazer
Aug 18, 2007 | Zenith SY2723BW TV
Toshiba 46SL417U LCD TV Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
