Question about Toshiba 46SL417U LCD TV
Replaced power board now remote and buttons on tv somtimes work and sometimes not work
    Top Expert:
  • Toshiba Master
  • 74,185 Answers
It sounds that there is some loose connnections. Check all the plug connections for any loose. Re-seat than once.
Posted on Jan 07, 2013
Remote with TV stopped working for vol, AV, and mute. Only power button works. Used new Batt; no change. Used buttons on TV; none work there too. Is there something broken on TV?
If the buttons on the TV -and- the buttons on the remote don't work, then there's definitely something wonky with the TV.
The good news is that the power works and the picture looks good. That rules out a bunch of things. If you don't mind tinkering, replacing circuit boards on TVs is pretty straight-forward -- just take off the back, unscrew the offending board and replace it. You'll have to do a little research to narrow down to the right board to replace -- it might be this key controller board:
http://www.shopjimmy.com/panasonic-tnpa4280s-gs-board.htm
May 04, 2016 | Panasonic TH-50PX75U Plasma HDTV
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
Lighting was bad in my area and my tv was plugged inns surge protector the tv turned on bit the power light blinks with the opc light my dish won't how up on the tv what do u think is wrong??? I turn...
The tv have a problems with the board that called the tv main Tuner signal board.That the board where the tv incomming broadcasting signal cable plug into it.This tv it still useable.I have one too a 46".Try tv unplug,replug it back like about an hour this problems will solved for a while evenually will return though.Every times POWER and OPC LED lights flashes,just push the tv power button ON again on the remote and have to wait,sometimes tv it will lite up and work right away.Sometimes it will have POWER and OPC LED lights flashes again.Just have to push the remote power button ON again and wait a while again eventually tv it will lite up and work.Have to this like 3 or 4 times power ON button pushes somtimes,tv will eventually work though.I know i do this manytimes before my tv have this problems off/on 3 1/2 years.But finally u will have to replace the tv main Tuner signal board sooner or later though this solution dosen't work for the rest of the tv life.U can do some basic mechnical works like take things aparts and putting back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Turner signal board for the replacement.
Sep 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
NEED CODE FOR TV REMOTE
have you tried hitting the code button then tv button then off button till tv turns off that always works for me im always replacing remotes make sure you go slow...and somtimes you can get them from the websites manufactor..
Apr 12, 2011 | Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
Mother board
Check you power button is unserviceable.
Open the cabinet disconnect the power On cable from front panel and short with screw driver for starting if computer is working fine. then power on switch is unserviceable,
Check the power supply also
Jul 04, 2008 | Intel Motherboard
Toshiba 46SL417U LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
