It turns on when plugged in butt ont hold a charge it wont turn on when i try to turn it on help
GO TO SETTINGS" .... SCROLL DOWN TO "PHONE STATUS" AND CLICK ON IT. iF IT SHOWS "DEAD" BUT YOUR PHOPMR STILL POWERS UP ... YOU HAVE A FEFECTIVE CHARGER, ALSO ... TRY DRAINING THE BATTERY. THEN SHUT THE PFONE POWER OFF FOR TILL THE CHARGER IS COOL TO YJR TOUCH. LEAVE YOUR PHONE OFF AND PLUG THE CHARGER IN FOR 3-4 HOURS. oNE OF THE TWO SHOULD TELL YOU WHAT IS BAD
SORRY FOR THE MIS-PRINTS.
MY RAZOR SHOWED NO GREEN POOWER BAR ON THE FRONT BATTERYS DISPLAY. SO I WENT TO "SETTINGS" AND FOUND "PHONE STATUS" I CLICKED ON "BATTERY"....IT SHOULD SHOWS A "+6" IF CHARGED. ("NO MATTER WHAT IT READS, TRY "MY SUGESTION") "IT IS IS ONE OF MANY POSSIBLE SOLUTIONS.
MAKE SURE BATTERY CHARGER IS UNPLUGGED ,BUT STAYS CONNECTED TO PNONE CHARGING PORT.CHECK PHONE CASING IS COMPLETELY COOL !!! FOR AT LEATST 1 HOURS ... AFTER ALL COMPONENTS ARE COOL......
THIS WILL DICHARGE ANY NMRMORY IN CHARGING SYSTEM.
NOW ...MAKING SURE CHARGER, BATTERY, AND PHONE ARE ALL COOL TO TOUCH, LEAVE PHONE OFF AND CHARGE IT LIKE THE BATTERY IS JUST LIKE IT COMES FROM THE FACTORY.
BE SURE TO CHECK CHARGER ,BATTERY, AND PHONE, DURING THIS CHARGING TO MAKE SURE THAT THERE IS NO HEAT (110 to 130 degs>) IS hot !!!!!!
IT WORKED FOR ME HOPE YOU THE BEST.
Works when plugged into the wall but gets hot sometimes reads unable to charge and sometimes it says charging but takes 10-12 hours to charge and only lasts a short time even if not on a call,phone is hot while plugged in and I have tried other batterys and chargers?
