Question about iRobot Roomba 4210 Bagless Robotic Vacuum
How to update firmware in Roomba 4210 4xx 4xxx
Changing the language on roomba pet series
You need to post a model numbers before I can help you.
Now, a three second search of the roomba help section on the roomba website turned up this:
All Roomba 700 Series and select 500/600 Series can provide troubleshooting messages in either English, French, German, Spanish, Italian, Dutch, Danish, Swedish, Norwegian, Finnish, Polish, Russian, Portuguese, Japanese, Korean, or Chinese.
Roomba's default language is English.
700 Series: Instructions for Setting the Language
  1. Turn ON your Roomba by pressing CLEAN.
  2. Press and hold DOCK until it beeps and says the current language.
  3. Release DOCK. Roomba is now in Language Selection Mode.
  4. Now press CLEAN repeatedly until you hear the language you want.
  5. Press and hold CLEAN to turn off your Roomba and confirm language choice.
500/600 Series: Instructions for Setting the Language
  1. Turn OFF Roomba. (Press and hold CLEAN until Roomba's lights turn off.)
  2. Press and hold CLEAN until Roomba beeps and says the currently selected language.
  3. Release CLEAN. Roomba is now in Language Selection Mode.
  4. Press CLEAN repeatedly until you hear the desired language.
  5. Press and hold CLEAN to turn OFF Roomba and confirm the language choice.
Jan 25, 2014 | iRobot Roomba 550 Vacuum
I roomba wont dock
That's usually caused by a charging issue. Could be that the contacts the roomba uses to charge on the base are bad or the contacts on the roomba its self. Here is a good troubleshooting guide. Roomba customer service is very good too, if the roomba is less than a year old they will repair it for you. good luck!
Jul 19, 2013 | Vacuums
I have no instructions for my roomba 560 so dont know how to start it
Turning Roomba on and off • To turn Roomba ON, press CLEAN once. You will hear a beep and the CLEAN button will light. • To start a cleaning cycle, press CLEANagain. Roomba will start a cleaning cycle. • To pause Roomba, press CLEAN while Roombais cleaning. • To turn Roomba OFF, press and hold theCLEAN button until Roomba's lightsturn OFF.
Sep 21, 2011 | iRobot Roomba 560 Robotic Vacuum
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Just goes in a small circle, no lights to indicate problem
Actually it very well can be bad or dirty sensor that you can clean with rubbing alcohol and cotton swab. If cleaning the sensor doesn't help, then it may be a firmware or electronical problem like faulty resistor or capacitor
Aug 27, 2009 | iRobot Roomba 530 Robotic Vacuum
My Roomba Discovery doesn't appear to hold a charge
cor2an,
That sounds like a classic battery failure in the Roomba discovery series. There are sensors inside the battery pack that go bad too. Either way...it's not very practical to repair the battery....the best shot you have would be to order a replacement battery. You just pop the old one out and then put the new one in.
They are available from iRobot for $69 at this link: http://store.irobot.com/product/index.jsp?productId=2799714&cp=2804606.3358509&ab=CMS_AccSuper_Roomba400_102308&parentPage=family
There are sources of less expensive (about $35) Genuine iRobot quality batteries also. You could try www.RoboticVacParts.com at this link: http://cgi.ebay.com/OEM-iRobot-APS-battery-Roomba-400-4XXX-Discovery_W0QQitemZ270412120603QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef5d1821b&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Jun 21, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Goes in circles
If you have the 4XX series or 4XXX series then your issues are coming from the sensor in the wheels. You will need to clean them PROPERLY.
Jan 26, 2009 | iRobot 4150 Roomba Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
237 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
