Question about Dual XDVD8181 Car Video Player
My dual xdvd8181 head unit will not power on. i bought it used and tried the old power wires to positive side of battery and ground to negative side and nothing happens. the in line fuse on the power
I have not actually hooked the whole head unit up to my vehicle's factory radio wires inside the dash. like i stated in my question i was just trying to see if the thing would power on by touching the power wires from the head unit as well as the ground wire to the positive and negative side of my car bettery. i have heard by doing that the player should power on or light up or give me some notification of the unit actually receiving power, but when i did that nothing happened!
  • Dual Master
  • 32,281 Answers
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Posted on Jan 07, 2013
  • dmoneylive
    dmoneylive Jan 07, 2013
    i never disconnected my battery though. i simply turned my car on my factory radio comes on along with everything else then i popped the hood, took my dual in dash head unit to the car battery and tried to touch the power and ground wires from the head unit to my car battery while the car was running and the head unit didnt do a thing.
SOURCE: blue screen will not go away
These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes. WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk. STEP ONE. Ground the E-Brake wire. No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground). 1. FACTORY RESET METHOD (Temporary) (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.) ** Go to the Menu ** Get to the Settings Menu ** Select to Reset to Factory Settings. Credit: DKA Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost. ---------------- 2. AUDIO CD METHOD (Permanent) ** Insert Audio CD ** Press PLAY ** Press STOP twice on remote ** Enter 26604 on remote ** Press ENTER ** Take out Audio CD and Insert a DVD Credit: Myself via a DUAL Tech ---------------- 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Credit: Adam P. The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Posted on Oct 01, 2007
SOURCE: how to by pass the e brake wire
easier solution is to join the yellow/blue wire to the white/ brown wire for the reverse light switch and hey presto
Posted on May 17, 2008
SOURCE: dual xdvd8181
i KNOW HOW TO FIX THIS PROBLEM, VERI COMMON ON SOME DUAL MODELS.
SEND IT TO ALLTRONICS IN HILLSBORO OREGON $125.00 AND THAT INCLUDES SHIPPING UNIT BACK, WITH 6 MONTHS WARRANTY.
Alltronics
Posted on Sep 04, 2008
  • 5 Answers
SOURCE: i need to bypass the parking brake wire on my dual xdvd8181
ground it to the radio
Posted on Jun 27, 2009
walesarumi
  • 6993 Answers
SOURCE: My dual xdvd710 was working
your dual xdvd710 is having a power problem. The power board is defective that's why the dual xdvd710 is not powering on. One way or the other, the power board has been affected.
A component on the power board like capacitor may have been defective.
Detach the dual xdvd710 from the truck, get a screw driver, disassemble the dual xdvd710. Use a meter to read the power board of the dual xdvd710, in other to detect the bad component. Make necessary replacement and the dual xdvd710 should power on again.
Purchase the replacement online or at any electronics accessories store within your vicinity.
Good luck.
Posted on Dec 06, 2010
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
How do I wire the system
You would require an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire.
The complete installation process is as follows
#1
Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
#2
Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
#3
Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
#4
Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
#5
Put the fuse in the fuse holder.
#6
Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
#7
On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
#8
In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
#9
Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
#10
Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
#11
If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
#12
Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
#13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. You are all done!
Hope this helps
Thanks
Oct 08, 2010 | Jensen XA2250 Car Audio Amplifier
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Ground Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
DUAL XDVD8181
I need the bypass code for a xdvd8181
Nov 02, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 31, 2008 | Dual XDVD8181 Car Video Player
CAN I ADD A TV TUNER TO MY DUAL XDVD8181 HEAD UNIT
just hook up a vhs or dvd player from home that has tv outputs, but you would need a power inverter for the power supply of the vhs, then put the vhs audio and videos outputs to the dual's input: the auxiliars. make sure the vhs has channel changing.
Jan 08, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
102 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
