Question about Singer 5417 Mechanical Sewing Machine
When i am sewing the stiches on top, but its at the bottom
The back of my fabric is a mess,,,the front stitch looks fine but the back is really messed up. Thread is not tight and its a jumble mess.
  • Singer Master
  • 7,365 Answers
Change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Posted on Jan 07, 2013
4 Suggested Answers
kent581
  • 87 Answers
SOURCE: bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
  • 1788 Answers
SOURCE: My machine is making a loud knocking sound and the
It is usually your top threading causing the problem. Totally rethread, make sure that the thread is not tangled, put in a new needle, now with the presser foot up, pull on your top thread, it should pull smoothly, then lower the presser foot, it should barely move. This should seat the thread in the tension discs. It probably would not be a bad idea to clean and oil your machine now, too. I don't know if you would want to, but I have taken off the throat plate and found lots of lint in there that I wouldn't be able to see otherwise. It almost looks like felt sometimes and there shouldn't be any "felt" there. I hope I helped you.
Posted on Dec 08, 2010
  • 233 Answers
SOURCE: singer sewing machine bobbin thread knots rather
What you have going on is a bobbin problem. The knots are referred to as birds' nests and happen when your bobbin thread gets caught on a piece of the bobbin casing. The large, loose stitches are normally caused by a problem with the bobbin case, a bobbin that is would properly, or when you're getting to the end of the bobbin's thread and the thread is loosely would on the bobbin at that point.
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
This should take care of the problem. If, for some reason it doesn't, you may well have a problem ALSO with your bobbin tension, and that should be looked at by a Singer Technician. You can find one in the yellow pages near you or probably by searching Yahoo Local. Happy Sewing.
Posted on Apr 04, 2011
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
Sewing velcro - my machine misses stiches so big gaps in the sewing - Do I use a different foot?
Make sure you are not using velcro with adhesive, that will really mess up the stitching. Otherwise, be sure to use a larger needle, like a #14 or larger. Also, be sure the needle is brand new and sharp!
Feb 28, 2017 | Sewing Machines
Setting tensions
Adjust your top tension if it's too tight. To decrease your top tension if it is too tight, turn your knob so the numbers are decreasing. Try ½ to 1 number lower, then test the stitches on a piece of scrap fabric. Continue until it looks even on both sides and you can no longer see the bottom thread on the top.
How to Adjust the Tension on a Sewing Machine: 13 Steps
www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Sewing+Machines+Setting+tensions
Dec 23, 2016 | Sewing Machines
Singer Sewmate, the zig zag stitch is perfect on the bottom of the fabric, but lopsided on the top, how do I fix this?
This could be a combination of two things, to much down pressure on the spring loaded foot on top or the fabric distorting it, the other is a top stich tension issue adjust tension in and out to see if this improves the stich.
good luck
Feb 25, 2015 | Singer Sewing Machines
Tension wrong on sewing genie , bottom stich just makes a huge mess
Begin with tension setting in the middle of it's range. If the stitching improves tighten until it's perfect. Ps "Sewing Genie" isn't a real sewing machine... apologies.
Jul 19, 2014 | As Seen On TV Sewing Genie Mechanical...
I have a brother vx-1125 and the top stich is fine but the bottom one is a mess, whats the best setting to have it on for a normal straight stitch?thanks
If the bottom stitching is a mess it usually means that the TOP thread is not threaded correctly. What happens most of the time is that the thread is not snug in the tension discs. First re-thread your machine with the presser foot UP and when you get to the tension discs (sticking up at the back of the machine) hold your thread like you're flossing and go back and forth in the disc to make sure you have tension on it. You should hear a little click when it's in there. (Test it...floss it on and pull it off so you can hear the click.) If the thread isn't between these discs your bobbin thread will be loopy. Finish threading the machine and you should have no problem now. Also, make sure your upper tension is set at 4 and your stitch LENGTH (on the right front) should be 2.5 or 3 for a normal stitch. Hope this helps. Let me know! Thanks for using FixYa
Sep 10, 2010 | Brother XL-2600
Stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Aug 24, 2008 | Kenmore 15516 Mechanical Sewing Machine
Singer 5417 Mechanical Sewing Machine Logo
170 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
