Question about Vizio VO42L 42 in. LCD TV
Can the bracket that the stand attaches to on the vizio e601i-a3 be removed?
I want to mount my vizio e601i-a3 on the wall. I have removed the stand, but i cant see how to remove the part of the tv that the stand screws on to.
daniel719
  • 240 Answers
SOURCE: We would like to mount our L37 HDTV 10A on the wall.
a wall bracket plate must be installed.
check with your local radio shach.
Posted on Jan 11, 2009
budmrtn
  • 11361 Answers
SOURCE: I need to attach a
They are Metric screw either M4, M5 or M6, you can get them at HD or LOWES for about 35 cents each. The length of the screw should be about 3/8 inch beyond the screw hole.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 01, 2010
  • 320 Answers
SOURCE: I have 32 in Vizio and am using a full motion wall
To know the exact size of the screw, you have to get the circumference of the hole where you will insert the screw. If possible to bring with you the outer mounting in buying the screw to have a perfect fitting.
Posted on Nov 30, 2010
SOURCE: I just buy a vizio
I've got the same problem. There are three screws in the neck and I don't want to remove them if that's not how to remove the neck. The manual says to remove the base and neck but only describes removing the base. Leaving the neck would be unsightly, to say the least.
Posted on Dec 23, 2010
SOURCE: I have a 42 in. Vizio Galleria and need to remove
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Posted on Mar 13, 2011
How do I remove back cover from Vizio E601i-a3 60" tv once all screws are removed? Still seems tight around the edges? Thanks
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations.
Dec 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How to fix no picture on vizio e601i-a3
Try the flashlight test for image in a darkened room. If you see image checkout the inverter board.
Mar 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Vizio E601i-A3, blue vertical line on screen in center.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 07, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My vizio e601i-a3e doesnt come on, no led , checked power and the wall and it is good
Go to you tube type in your question and you should get the video you need to sort out your problem .
Dec 21, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Vizio VO42L 42 in. LCD TV Logo
65 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
