Quiero programar el control xfinity co mi tv etec
VOTIT
  • 2071 Answers
SOURCE: no puedo programar el control
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
SOURCE: auxilio
aprogramo un control universal marc proscan nose com programarlo nesecito a
Posted on Jan 23, 2009
  • 325 Answers
SOURCE: necesito los codigos para programar el control
Sharp 011,020,025,027,037,052,053,059
cheers
Little Dish Fitter
Posted on Oct 11, 2009
farmerbear
  • 490 Answers
SOURCE: cual es el codigo para programar el control de
Hola. Estoy utilizando un programa del traductor. Aquí está la lista de televisiones que funcionen con el DISHNETWORK teledirigido: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml Su televisión no aparece en la lista. Lo siento. Respetos, FARMERBEAR
Posted on Aug 31, 2010
SOURCE: nesesito el codigo de un tv jvc para programar
COMO BUSCO EL CODIGO DE MI CONTROL REMOTO DE MI PUR FLAT?
Posted on Sep 27, 2010
Quiero programar el control de dish a mi tv lg
No es possible in most cases--el control de dish no trabajo.
Oct 29, 2012 | LG 42LC2D 42 in. LCD HDTV
Tengo un control de sony RM-YD014 quiero el manual o el codigo para programarlo otra ves a mi televizor
REMOTE CODES & PROGRAMMING INSTRUCTIONS RM-YD014 The RM-YD014 remote control is not programmable and remote codes are not required. This remote is designed to control the product that it originally came with. If the remote has buttons for other product types (TV, DVD, etc.), it can control only Sony branded versions of these products. Please note that this remote may not be able to control all models of these other Sony product types.
Jun 12, 2012 | Sony RMYD014 Remote Control
Quiero el codigo para programar tv emerson
vaya a www.fitness.manualsonline.com or www. remotecodelist.com
Dios le bendiga
Jun 11, 2012 | DISH Network IR Remote Control
Como puedo programar una tv samsung con el control de dish
Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
Kimberly Escobar
DISH Network
Aug 07, 2011 | DISH Network IR Remote Control
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Mi caja convertidora es zenith y quiero programar el control de la caja convertidora con mi television zenith
como puedo conseguir el control remoto de mi caja covertodora se me descompuso y no puedo programar mi senal
Jan 30, 2011 | Abt Television 1745 Remote Control
Como programarla ala tv
Hola mi nombre es Mayra Diaz con Dish Network. Con much gusto le puedo ayudar a programar su control a su televisor. Primero que todo necesitamos saber cual es la marca de su televisor para darle los c?digos que funcionen con su televisor espec?ficamente.
Aug 15, 2010 | DISH Network IR Remote Control
Ayudame por favor
necesito programar el contorl
Jun 21, 2008 | RCA RCR311B Remote Control
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
