Question about Westinghouse 46" LED TV HDTV 120Hz Full 1080P
My tv just shut off and wont turn back on not even 1 year old
Version number tw-62401-u046a
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: vertical colour bars
The problem is in the LCD controller board is overheated because the power supply unit is at the bottomof the TV and the heat rises upward to the vent on the top of the TV. You can verify that is hest problrm by running TV with the back removed and have a small fan blowing on the top secdtion of the TV where the LCD controller is. This how I fixed my scrambled picture after warm up (I added heat sinks to the IC on the LCD controller board) : http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You can try it if the board was not badly damaged already by the heat. My has been running great for over a month now.
Posted on Feb 05, 2010
Wondering if its my main board on my hdtv flat screen. it comes on normal for about 10 to 15 seconds then i lose video but not audio
sounds like a failing t-con board. this board is on the back of the screen controls the signals to the screen. ribbon from main board goes to the t-con board.
Jan 28, 2017 | Westinghouse Televison & Video
Westinghouse TW-62401-U046A is not working. It doesn't power on unless I unplug the ribbon cable for the right backlight. It looks like this is a common problem, but is there an easy fix besides installing...
The ribbon cable may not be making a complete connection on all pins. Contact Westinghouse and ask for a replacement cable to a void the problem.
May 10, 2014 | Televison & Video
My westinghouse 46" led tv will not turn on, tested the ac power supply and its good
The problem might be of its mother board itself. Contact any experienced service technician to make it confirm before change it. There are so many adjustments should be done after changing a new mother board. It is not a user reparable work.
Jan 16, 2013 | Westinghouse Televison & Video
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
Sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
Dec 27, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Tv just wont turn on
power supply fault it could be any component if not qualified dont risk taking a look inside, high voltage supply.
Oct 14, 2007 | Panasonic (LSSQ0372) Remote Control
Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Westinghouse 46" LED TV HDTV 120Hz Full 1080P Logo
387 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
