Question about Fuji FinePix S5000 Digital Camera
Fuji Finpix 5600 digital camera. Can I change the aspect ratio to 4:3 on this camera, thanks
I want to take my own passport photo and need an aspect ratio of 4:3ratio
SOURCE: Fuji Finepix s1000fd i/o error when loading photos to PC
I had same problem,Vista/Fuji-finepix.
Go to control panel click on Autoplay, camera is under devices probably says " take no action" with red sign.click on the bar and a drop down appears,click on import to windows or ask me first,click save and it should work fine. i uninstalled the fuji software,i assume it has issues with microsoft settings.
Posted on Aug 08, 2009
  • 186 Answers
SOURCE: s 5600 finepix fuji camera - card error
Test the card in another device(computer)to see if it works.If so the card capacity may be too large for the camera.
Posted on Sep 22, 2009
fathitkf
  • 1871 Answers
SOURCE: Fuji FinePix S8000fd Digital Camera I have
Hello :
Lens error is the most common failure in digital cameras . it seems The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system . or it could have been something as small as a bump while it was being carried in your pocket or even the sand or something like it can cause this problem . Anyway the problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that manufacturers say it happened during usage. I recommend you to contact the manufacturer to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky . Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Fuji first and see what they have to say about cost of repairs. Once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
PLEASE DON'T FORGET TO RATE !
good luck
Posted on Apr 11, 2010
dlundmark
  • 797 Answers
SOURCE: my FUJI FINEPIX S5700 Digital Camera keeps saying
You may not be able to. However let us try. Reset all menus to default, or factory settings. Another way to do it, possibly is to remove all batteries and let the camera sit for at least 24 hours, then put the batteries back in and try it.
You may need repairs.
Posted on Apr 22, 2010
lock123
  • 6831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
How do you change the stills function from 4.3 to 16.9 its really not very clear?
Hi
Having looked at the full manual - downloaded from here and savable:
http://tda.panasonic-europe-service.com/docs/2z54662404z3z38916z656ez706466z22zdf06e277f71e6367f9e09db70241478cb0ad23ae/tsn3/data/ALL/HXWA30EG/OI/902781/vqt4x32.pdf
I think you will find that you cannot actually change from 4:3 to 16:9 aspect ratio for a particular pixel sized picture. When you set the pixels for the picture you want, the aspect ratio is set automatically.
For example:
16Megapixels 4608x3456 4:3
12Megapixels 4608x2592 16:9
See page 96 of the manual mentioned above for a full table of Megapixels, size, ratio etc
Therefore changing the picture size from the simple menu changes the aspect ratio but you do not have control of the aspect ratio for each size, in other words you cannot take a 16Megapixel picture at 16:9, it has to be 4:3.
Hope this has been helpful
Cheers
Nov 14, 2014 | Panasonic HX-WA30EB-K Hx-wa30 Upright...
I have a Photosmart D7360. Recently when printing straight from the memory card, the images are too dark. I have to adjust the brightness to maximum for an acceptable print. Why should this have suddenly...
Introduction
The purpose of this document is to provide background information on the cause of photo cropping or the cutting off of images when they are printed. Photo cropping occurs as a result of disproportional horizontal and vertical dimensions, or Aspect Ratio.
Understanding Aspect Ratio
Each image size has a different Aspect Ratio that is determined by the digital camera or other device used to capture the image. If the Aspect Ratio of the print size is equal to the Aspect Ratio of the image, no cropping of the image occurs. However, if the Aspect Ratio of the print size is not equal to the Aspect Ratio of the image, the image will be cropped until the Aspect Ratios are equal.
Examples of photo cropping caused by disproportionate Aspect Ratios
A digital image of 1280 x 960 DPI (resolution - dots per inch) has an Aspect Ratio of 4:3, which, unless cropped, will result in two sides having white borders on the printed 4 x 6-inch picture. Instead of leaving the white border, the printer will increase the size the the image, center it on the paper, and finally crop the image so that the image ratio is 3:2, the Aspect Ration of a 4 x 6-inch photos (see Figures 1-4).
Adjusting Aspect Ratio
When using a digital imaging program to eliminate unwanted sections of images, the Aspect Ratio will change. Many newer digital cameras offer a 3:2 resolution setting that creates a borderless 4 x 6-inch picture. Check the digital camera user's manual to see if this feature is supported. When using a digital imaging program such as Adobe Photoshop Elements software, images can be cropped to the desired size as long as the Aspect Ratio is correct. The software should provide pixel size information to better determine the appearance of the printed picture.
To convert an image to a 3:2 ratio, divide the smallest pixel number by two, multiply that number by three, and replace the larger pixel number, the width of the image, with this new number. This will determine the correct Aspect Ratio for a 4 x 6-inch picture.
Example
For an image with a ratio of 100:50, divide 50 by 2. The resulting number is 25. Multiply 25 by 3. The resulting number is 75. Replace 100 with the 75. The new desired Aspect Ratio for an uncropped 4 x 6-inch picture is 75:50. The image settings can now be modified to a ratio of 75:50 with a digital imaging program.
hope this may help,
regards,
VOTIT
Jul 28, 2008 | HP Office Equipment & Supplies
Need reolutions 4 my finepix HS35EXR
This camera does not allow the user to set resolutions. This camera only allows the used to choose between 3 different sizes of pictures and 3 different aspect ratios (which is basically the same thing)
To change the picture size, you use the shooting menu and scroll down to image size.
I've included the link to the manual for the camera, it's from the Fuji site, and a screen cap of the image size instructions.
BTW, folks here are volunteers... they do this for free.
https://www.fujifilmusa.com/shared/bin/HS35EXR%20manual.pdf 1d9766fb-4792-4bfc-908c-eb3129a6782c.jpg
Mar 06, 2014 | Fuji FinePix Cameras
How do i resize picture to square aspect ratio ? that is to resize 640x480 pixel to 600x600 pixel without stretching the photo or changing the aspect ratio
Well, you can't. The best you can do in a photo-editing program such as Photoshop Elements, is to crop the picture to square dimensions.
Oct 28, 2009 | Sony Mavica MVC-FD92 Digital Camera
Feb 08, 2009 | Fuji FinePix S2000hd Digital Camera
Help me
Most digital SLR cameras take pictures with an aspect ratio of 2 to 3. (This is based on the size of 35 mm film, where the images were 24 x 36 mm, a 2 to 3 ratio.) That is a different ratio than 8 x 10 inches, which is 4 to 5. There is no way to change the aspect ratio in the camera, so you will have to make sure when you're taking pictures that will be printed on 8 x 10 paper, you leave the processor extra area to crop the portion that won't fit in the 8 x 10 frame.
For information, the 8 x 10 picture became popular when many portrait photographers used 4 x 5 large format film cameras, which obviously will fit perfectly in an 8 x 10 frame without cropping.
Mar 22, 2008 | Canon EOS-20D Digital Camera
Help me
The sensor in most digital SLR cameras has an aspect ratio of 2 to 3. This is based on the aspect ratio of the film used in 35mm film SLRs, which was 24 x 36 mm. This works fine when you print on 4 x 6 paper (a 2 to 3 ratio), but not on 8 x 10 (which is a 4 to 5 ratio). Something has to be cropped in order to fit. You can't change the physical size of the sensor in the camera, so you will have to allow for some cropping if you are going to have your images printed on 8 x 10 paper.
For information, the 8 x 10 size became popular when many portrait photographers used large format 4 x 5 cameras. This obviously can fit perfectly on 8 x 10 paper without cropping.
Soft ware for fuji a345 to windows vista
This stinks. Just got this new computer with Vista Premium windows and now, cannot use
my FinPix 345 digital camera. Thanks Fuji
sanje43@yahoo.com
Feb 09, 2008 | Cameras
Process Cropping
Most digital cameras have an aspect ratio of 4x3. 35mm cameras have an aspect ratio of 3x2. 6x4 photopaper also has an aspect ratio of 3x2. Therefore you don't get cropping when printing from 35mm film. To make the picture fill out the 6 inches, the digital footprint has to be 6" by 4.5". So .5 inches is removed in the process. If you can find a processor that will print 5.333 x 4 on the 6 x 4 paper, there would be no clipping necessary. Since you have Photoshop, you can crop the photo to a 3 x 2 ratio. That way you control what is cut. I use Photoshop Elements and when I use the Rectangular Marquee Tool, I set Style to "Fixed Aspect Ratio" and Width to 3, and Height to 2.
Sep 14, 2005 | Creative Labs PC-Cam 300 Digital Camera
How to change aspect ratio
That sounds like the setting. You would be using less pixels with the 3:2 aspect ratio. Since you said you had cropped the photos prior to sending them to the printer, you could have cropped them to a 3x2 ratio. I do that often. I use Adobe Photoshop Elements and when you use the selection tool, you have the option of setting the aspect ratio to 3:2 or anything. Then every selection rectangle will be 3:2 and you only have to decide how large to make the rectangle and where to put it. Then when you do the crop, you get a perfect 3:2 ratio photo. When you select the rectangular marquee tool (selection box) the Options line will appear just below the row of shorcut icons. If it does-not, click on the "Windows" button at the top of the page and make sure that "Options" has a check-mark beside it. On the Options line you will find a box that says "Normal". Click the "V" to the right of "Normal" and select "Fixed Aspect Ratio". Then in the two boxes to the right enter the numbers Width 3 and Height 2.
Aug 30, 2005 | Kodak EasyShare DX7590 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
